BKP Motor: Adjusting New PDE?
yanliz
2004 Audi A4 Avant
Post01-08-2010, 21:24    Subject: BKP Motor: Adjusting New PDE? Quote
My friend has a Passat 3C with the BKP engine.
"As of today, the engine will not start. The error memory contains the following:"
005399 - Stromversorgungsrelais für Motorsteuergerät (J271 o. J363): elektr. Fehler
P1517 - 007 - Short circuit to ground - Intermittent.
008518 - Fuel injector(s): Disconnection.
P2146 - 009 - Short to ground.
I had him test all the injectors. On the third cylinder, there is continuity from pin 1 to ground.
I'm not entirely sure anymore, and I can't find any relevant threads about it. Does the new component need to be adjusted to the engine control unit? If so, does anyone know which adjustment channel is required?
Audi A4 Avant 1.9TDI MJ2004
MKB: AVF, GKB: HCF 6-Gang
Translated on 16-09-2026, 20:32.
goettmann
Post01-08-2010, 23:30    Subject: BKP Motor: Adjusting the new PDE. Quote
No!
Have you checked the PDE wiring harness?
Translated on 16-09-2026, 20:34.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post02-08-2010, 5:39    Subject: BKP Motor: Adjusting New PDE? Quote
Unfortunately, you have to purchase the PDE from BKP through an authorized dealer. These are Siemens injectors, not Bosch injectors. They are not available through regular retail channels.
Passat Variant BGW 2005
yanliz
2004 Audi A4 Avant
Post02-08-2010, 9:41    Subject: BKP Motor: Adjusting the new PDE. Quote
goettmann wrote:
No!
Have you checked the PDE wiring harness yet?
No, the wiring harness between the head and the control unit has not yet been checked. But the PDE (presumably a sensor or module) and the wiring harness (for safety) will be purchased from the dealer. The short circuit is located within the PDE itself.
Thank you for your help.
Translated on 16-09-2026, 20:35.
jorgmann
Post14-08-2010, 13:52    Subject: BKP Motor: Adjusting New PDE? Quote
In your case, the PDE needs to be replaced. This requires the adapter kit for the cylinder head. Including the screws and repair kits for the PDE, the total cost will be approximately €700, plus about 3 hours of labor.
You actually need to adjust the CR valves.
There is a TPI document about it.
Translated on 16-09-2026, 20:36.
No new posts Differential pressure sensor G450 to be calibrated/adjust... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Motor - Motor klappert, Leistungsmangel, Schwarzrauch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts agr new problem Diesel Engine Technology
No new posts Do I Need a New Control Unit? On-Board Diagnostics (OBD)
No new posts VAG Struts: New Suspension Upgrade Transmission, Chassis, Body & Interior
No new posts HEX-USB+CAN, KEY-USB, HEX-USB, new Windows and drivers On-Board Diagnostics (OBD)
