Golf 1J Headlight Washer Pump Leak - Repair Guide (Solution)
Michael II
Post07-03-2003, 9:47    Subject: Golf 1J Headlight Washer Pump Leak - Repair Guide Quote
Headlight washer pump leaking, pump housing cracked.
Cause:
Due to manufacturing tolerances in the headlight washer pump, it can crack and become leaky under thermal stress, particularly in very hot climates.
Solution:
Spare part.
Tschüss
Michael II
Translated on 11-10-2026, 1:23.
Ratings - Golf 1J Headlight Washer Pump Leak - Repair Guide
No new posts Golf 1J Radiator Leak: Repair Guide & Info Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A6 4B, Fog lights leaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B2 CV Joint Leak: Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Headlight Washers Not Working? Fix It Now! Transmission, Chassis, Body & Interior
No new posts Golf 3 '97: Sunroof Seal Leak? Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Leaky Golf 3 Radiator: Other Causes & Fixes Diesel Engine Technology
No new posts Golf 3: Pump Düse Conversion Guide On-Board Diagnostics (OBD)
