be presenting me with the yellow gas lamp in the near future, or not? }
Well, if the dataset is designed cleverly, it will first try without using the light, and only if that doesn't work, it will use it.
I think I'm going to head straight to the sauna after work to relax and sweat it out.
And precisely this problem leads me to believe that the particulate filter is absurd... it's supposed to protect the environment, but we have to drive around for it to burn off... it constantly frustrates me and makes me angry about our cars.
To clean up the "green conscience" part again, which has caused additional CO2 emissions...
The same applies to other areas (in the automotive industry).
First, the cars are made with a flat front to allow them to cut through the wind with minimal resistance.
Now they're becoming more aggressive again, because someone realized that the pigeons are breaking the bones of poor pedestrians' feet.
Everything has two sides. But the "experts" in the legislature always focus on just one aspect, like a cow being lured into a slaughterhouse. And then their successors (well, there aren't any successors for the cow) rush out, screaming, and throw themselves onto the other side.
First, "we need to drastically reduce fuel consumption." Now, they're using diesel fuel in a way that creates such fine particulate matter that you can't even see it.
And then, a little bit of image-based propaganda for those who don't use regenerative braking on ultra-short distances...
