Passat 3C: Grinding Noise When Turning & Accelerating
linklon
Post14-02-2012, 0:26    Subject: Passat 3C: Grinding Noise When Turning & Accelerating Quote
Hello everyone.
"I have a scratching noise on my Passat 3C (lowered suspension) when cornering and during load changes. The noise seems to be coming from the area of the left front suspension and sounds like someone is scraping ice off the windows from the outside... but quieter. The noise is only audible for a short time during the load change. There is no noise when changing the load while driving straight."
I have already checked the control arms and strut mounts. I have also verified that the sway bar links and the engine mounting bracket are properly seated.
Does anyone have any idea where this noise might be coming from?
Perhaps ZMS?
Passat 3c 4 Motion highline BMP
Translated on 08-10-2026, 14:10.
servusssss
Post14-02-2012, 20:44    Subject: Passat 3C: Grinding Noise When Turning & Accelerating Quote
Take a look at the cuffs on the drive shafts.
Contamination on the brake disc or on the brake pads (stone, etc.).
Check the frame mounts inside the fork.
"Sg" is an abbreviation for "singular." It is used to indicate that a noun or pronoun is in the singular form.
For example, the sentence "The cat is black" uses the singular noun "cat." The sentence "He is tall" uses the singular pronoun "he."
In German, the singular form of a noun is usually indicated by the article "der" or "die." For example, the singular form of the noun "Mann" (man) is "der Mann." The singular form of the noun "Frau" (woman) is "die Frau."
The singular form of a pronoun is usually indicated by the pronoun itself. For example, the singular form of the pronoun "ich" (I) is "ich." The singular form of the pronoun "du" (you) is "du."
Translated on 08-10-2026, 14:12.
linklon
Post15-02-2012, 0:22    Subject: Passat 3C: Grinding Noise When Turning & Accelerating Quote
Thank you for your tip.
I had already looked at the suspension, brakes, and driveshaft before posting... unfortunately, without making any progress. However, yesterday (unfortunately, after the post icon_redface.gif), I found a promising lead here on the forum.
The sounds seem right... I'll definitely check it out by the weekend.
It seems the noise might also be related to the temperature, because today it was quiet (temperature yesterday -5° to -10°, today +2°).
Best,
Jan
Translated on 08-10-2026, 14:13.
Post15-02-2012, 11:54    Subject: Passat 3C: Grinding Noise When Turning & Accelerating Quote
Passat 3C lowered (factory lowering)
What is that?
A Highline model with the optional "sport suspension" package?
as if the noise also had something to do with the temperature,
Is that ice that's sliding around in the water reservoir or on the windshield frame?
It makes ugly noises and will disappear quickly at +2 degrees Celsius icon_smile.gif.
Translated on 08-10-2026, 14:15.
linklon
Post16-02-2012, 23:56    Subject: Passat 3C: Grinding Noise When Turning & Accelerating Quote
What is that?
Good tip... I love problems that solve themselves icon_wink.gif.
Translated on 08-10-2026, 14:16.
No new posts Passat 2000: Rear Brake Noise Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.9 PD-TDI ATD engine: hard shifting/jerking under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J documentary, noises during load changes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf V: Squeaking Noise When Releasing Gas Diesel Engine Technology
No new posts Passat 3C Variant, 1.4 TSI - Noises during load changes Transmission, Chassis, Body & Interior
No new posts Passat 3B: Shifter Knob Wobbles During Gear Changes Diesel Engine Technology
No new posts VW Passat 2.5 TDI: Power Loss & Noise Issues Diesel Engine Technology
