Brake from the Vitara
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
schrauber2904
Post16-09-2010, 21:53    Subject: Brake from the Vitara Quote
Hello, I have a Suzuki Vitara and I'm experiencing a problem with the brakes. They were stuck. I replaced the brake calipers because the pistons were seized. After that, I had to replace the master cylinder because it wasn't releasing the pressure. Everything worked fine after that, until now (2 months). Now the problem is starting again. Can anyone give me a tip on what else I can do? I'm really at a loss. It can't be that everything is defective again after such a short time.
No new posts Electric Brake (EPB) Diagnosis and Maintenance Troubleshooting & Guides
No new posts Document Passat, Model Year 2000, Brakes Stuck Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Bremse entlüftem Mk 20i Transmission, Chassis, Body & Interior
No new posts Bremse Passat Neu On-Board Diagnostics (OBD)
No new posts R32 Bremse HA an 85kw TDI ? Transmission, Chassis, Body & Interior
No new posts Brake Sharan 7N1 Transmission, Chassis, Body & Interior
