VW Passat: Check ALG NW Control Unit (3B5)
klemmi 2
Post20-09-2010, 18:19    Subject: VW Passat: Check ALG NW Control Unit (3B5) Quote
Hi everyone, I have a question about my Passat 3B5 with a V6 engine (MKB ALG). It has absolutely no power. The mass airflow sensor is new, and the swirl flap control system works during the actuator diagnosis. I then manually locked it and drove it, but nothing changed. My question is: Can I use VCDS to check if the Nockwell sensors are working correctly, and whether the valve timings are correct (I once read somewhere that they are often not installed properly, but I can't find the article anymore). Hopefully, someone can provide some answers. Thanks, Jürgen.
P.S. I know this isn't a racing car engine, but it should really be able to go over 180 mph, right? It actually does pretty well up to that point.
Translated on 20-08-2026, 3:06.
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Check Passat 3BG mileage Electrical Systems, Vehicle Electronics, Multimedia
No new posts Unterdruckpumpe prüfen Diesel Engine Technology
No new posts Check VP37 Diesel Engine Technology
No new posts Check two-mass flywheel. Upload
