Firmware Update Time: How Long Does It Take?
Jan03
2010 Volkswagen Polo
Post15-01-2013, 11:13    Subject: Firmware Update Time: How Long Does It Take? Quote
Hi!
"Does anyone know the approximate time it takes to update the software on Continental SIMOS MSG units in a Cayenne?"
The reason for this is that I want to have a software update done on my CAYB (due to TPI2021663/9). However, the icon_smile.gif -related people only want to charge me an hourly rate, and they absolutely won't give me any information about whether it will take 5 minutes or 10 hours. And with an hourly rate of 135€ here in Denmark, the cost can quickly become more expensive than simply replacing the MSG.
/Jan
Translated on 16-09-2026, 19:45.
chli1976
Post15-01-2013, 12:22    Subject: Firmware Update Time: How Long Does It Take? Quote
I just performed a CAY update on a Touran using ODIS, and it took about half an hour. GFS+ update.
VCDS
Translated on 16-09-2026, 19:47.
Post15-01-2013, 12:55    Subject: Firmware Update Time: How Long Does It Take? Quote
I have a brand new CAYC in my wider (auto-indifferent icon_wink.gif) circle.
What does TPI2021663/9 say?
Greetings.
Jan03
Post15-01-2013, 13:24    Subject: Firmware Update Time: How Long Does It Take? Quote
@chli1976Viewing profile: chli1976: Thank you very much. I hope that this person charges by the half-hour.
@dieselmartinViewing profile: dieselmartin: TPI2021663/9: "Engine: Loud combustion noises and/or hesitation/jerking during slight acceleration, delayed starting." (Release date: 12/14/2012). Depending on the MSG (Main System Module) and equipment, software 9614-9970 will be installed.
In Italy, people claim to know that this software represents the currently final software version for the CAYB. Don't ask me where they claim to get that information icon_confused.gif.
Translated on 16-09-2026, 19:48.
Post15-01-2013, 13:34    Subject: Firmware Update Time: How Long Does It Take? Quote
Damn.
This CAYC also had a loud rattling noise.
However, you did NOT install any updates.
Based on what the WSC says, that should be correct.
I don't have a "before" scan, only an "after" scan.
But you can still see it in the "programming attempts."
Code:
Adresse 01: Motor (J623-CAYC)       Labeldatei: RKS\03L-906-023-CAY.clb
   Teilenummer SW: 03L 906 023 MM    HW: 03L 907 425 C
   Bauteil: 1,6l R4 CR td H43 9919
   Revision: --H43---    Seriennummer: 00000000000000
   Codierung: 08114036030401080000
   Betriebsnr.: WSC 01357 011 00200
   ASAM Datensatz: EV_ECM16TDI02103L906023MM 003010
   ROD: EV_ECM16TDI02103L906023MM_VW36.rod
   VCID: 7DFA69B6ECEA4F1
Translated on 16-09-2026, 19:49.
Jan03
Post15-01-2013, 13:40    Subject: Firmware Update Time: How Long Does It Take? Quote
The (9919) is the latest version according to the TPI of the 03L906023MM. Unfortunately, I no longer have a warranty and will have to pay for it icon_sad.gif.
Translated on 16-09-2026, 19:50.
chli1976
Post15-01-2013, 16:00    Subject: Firmware Update Time: How Long Does It Take? Quote
In Austria, the latest software version isn't available yet; it's supposed to be on the DVD70, but the online data hasn't been updated for us yet.
VCDS
Jan03
Post21-02-2013, 15:27    Subject: Firmware Update Time: How Long Does It Take? Quote
Brief reply.
As mentioned, the update took approximately 30 minutes (from software version 5689 to 9970 on the CAYB engine).
Result:
- The slight instability in the quantity control at cold engine temperatures has been resolved (the thrust cutoff now engages with a slight delay).
Subjective changes:
- Increased starting torque.
- Softer cold start. It starts up less aggressively (idle speed and starter injection volume are slightly lower when starting below 0 degrees Celsius). As mentioned, this is subjective.
/Jan
Translated on 16-09-2026, 19:51.
No new posts EDC15: Updateable Engine Control Unit Software Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts HEX-NET Firmware update Server not reachable On-Board Diagnostics (OBD)
No new posts USB Adapter: HEX-V2 Firmware Update On-Board Diagnostics (OBD)
No new posts Firmware Update Failed: Troubleshooting & Solutions On-Board Diagnostics (OBD)
No new posts VAG-COM 704.1 Update to 805: How-to Guide On-Board Diagnostics (OBD)
