bindpe Blaumann
Joined: 08/25/2006 Posts: 203 Karma: +5 / -2 Location: ingolstadt
08-10-2010, 16:58 Subject: Rust on Golf III Servo Line - Need Help |
Hello.
I'm having the following problem:
The hose connecting the power steering pump to the steering rack on my Golf is rusted through.
It's probably called a "stretch hose." It now has a small leak right after it comes off the pump.
Has anyone ever replaced this thing before?
You can easily disconnect the hose from the pump, but how do I get it off the steering rack?
I would be very grateful for any tips.
Thank you.
| Description: |
| File size: |
14.3 KB |
| Viewed: |
16758 times |
| Description: |
| File size: |
14.3 KB |
| Viewed: |
8377 times |
Golf III TDI AHU 402Tkm
Translated on 13-09-2026, 17:35.
Herbert Profi-Schrauber
09-10-2010, 12:05 Subject: Rust on Golf III Servo Line - Need Help |
If the expansion hose is attached to the steering gear with a hollow screw, it should be removable with the steering gear installed. It's a fiddly job because the connection is somewhat hidden. I've done this before on my vehicle.
If the expansion joint has a threaded end fitting, the procedure may vary depending on the flexibility of the hose (---> repair instructions).
@ Admin - could you please check if these pictures can stay here, regarding copyright issues?
"vg"
This is a common abbreviation for "very good" in German. It is often used in online forums and chat rooms.
Translated on 13-09-2026, 17:36.
bindpe Blaumann
09-10-2010, 14:37 Subject: SEO: Best Practices for Website Optimization |
Hello.
Thank you for the information.
So, without a lift platform, there's no chance.
There is extremely little space between the engine mount and the body.
It can only be opened with a ring-shaped key that has an opening on one side.
Translated on 13-09-2026, 17:38.
golf3schrauber Blaumann
Joined: 10/15/2003 Posts: 140 Karma: +1 / -0 Location: Erkelenz
15-10-2010, 13:07 Subject: Rust on Golf III Servo Line - Need Help |
I still have some work to do. The pipes are still sealed, but they are already quite worn.
eaten away.
Have you changed the line yet?
I'm interested in knowing how well you understand the purpose of the lock nut on the steering linkage at the steering gear.
I was able to loosen mine, but yours seems very rusty. I'm afraid that loosening it will be a problem.
Gruss Oliver.
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
Translated on 13-09-2026, 17:39.
bindpe Blaumann
15-10-2010, 15:08 Subject: Rust on Golf III Servo Line - Need Help |
Hello.
Yes, I managed it, but it was impossible without a jack. If you can get underneath the car and apply force, then it's possible.
"My hoses were completely deteriorated (13 years, 320,000 km). I had sprayed them thoroughly with WD-40 the night before. I also had to get an open-end wrench because otherwise, you can't get a grip on them."
A leadership position at Volkswagen costs approximately 140 euros.
best regards
Peter.
Translated on 13-09-2026, 17:40.
