VCDS-S
2013 Volkswagen Touareg Free account, no CAN development support
10-04-2010, 0:11 Subject: Tire Pressure System Audi A4 B7 Door Control Unit |
Hello everyone,
I still have an error message in the car's memory for the tire pressure monitoring system, but I actually removed the entire system because there are no wheel sensors installed. Is there another way to disable this check?
Here's the path I followed to remove the system from the bill of materials:
STG 17 (Combination instrument)
ECU adaptation -> Function 10
-> Channel 61 (Data bus comfort features list)
There, I subtracted the value 00512 from the total amount.
"FIS is no longer displaying any errors, and the menu has also disappeared. Now, I have the following error code in the system memory:"
Address 65: Tire Pressure Label file: 8E0-907-273.lbl
Part number SW: 8E0 907 273, HW: 8E0 907 273.
Component: Tire Pressure Sensor 3 H04 0110.
Encoding: 0022222
Operating number: WSC 06435 000 00000
"One error found:"
01833 - Antenna for tire pressure monitoring system; rear (R96).
004 - No signal/communication - Warning light ON.
Environmental conditions:
Error status: 11100100
Error priority: 3
Error frequency: 1.
Lost Count: 40
Time: 0.
(no unit): 0.0
Voltage: 12.60 V
(no unit): 130.0
recognized
recognized
recognized
n. recognized
I hope you understand what I mean and have a solution. Thanks in advance!
Translated on 23-08-2026, 7:47.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
10-04-2010, 12:51 Subject: Tire Pressure System Audi A4 B7 Door Control Unit |
"Hi,"
Have you ever looked into the CAN gateway, address 19?
Quote: | | LC,03,0,[65] Tire Pressure Monitoring System |
Keyword: 'Long coding'.
Please always provide a complete scan, as it makes it easy and quick to see what components are installed and how they are configured.
Translated on 23-08-2026, 7:51.
Profile PM WWW Garage |
VCDS-S
10-04-2010, 17:33 Subject: Tire Pressure System Audi A4 B7 Door Control Unit |
"I can't access it; the control unit isn't responding!"
Okay, here's the entire log:
Friday, April 9, 2010, 09:39:35:42630
VCDS version: RKS 908.2
Data as of: 20100327
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag für einen Spaziergang."
Vehicle type: 8E - Audi A4 B6/B7.
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Vehicle Identification Number (VIN): WAUZZZ8Exxxxxx
Mileage: xxxxx km
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein wunderschöner Tag."
"The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze is blowing through the grass. It's a beautiful day."
Address 01: Engine Label file: RKS\06B-906-018-AVJ.lbl
Part number SW: 8E0 909 518 AQ, Part number HW: 8E0 909 018 B.
Component: 1.8L R4/5VT G 0010
Encoding: 0011501
Operating number: WSC 06325 000 00000
No errors found.
Readiness: 0000 0000
Address 03: Brakes Label file: RKS\8E0-910-517.lbl
Part number SW: 8E0 910 517 D, HW: 8E0 614 517 AK.
Component: ESP8 front panel H06 0120.
Revision: 00000000 Serial Number: 00000000000000
Encoding: 0004871
No errors found.
Address 08: Climate Control/Heating Label file: RKS\8E0-820-043.lbl
Part number: 8E0 820 043 BM
Part: A4 Climate Control Unit 2832.
Encoding: 00000
Operating number: WSC 00000
No errors found.
Address 09: Body Control Module
Label file: RKS\8E0-907-279-8EC.lbl
Part number: 8E0 907 279 L
Component: Internal load module ECE 0704.
Encoding: 11021
Operating number: WSC 65536
No errors found.
Address 15: Airbag
Label file: RKS\8E0-959-655-94.lbl
Part number SW: 8E0 959 655 G, HW: 8E0 959 655 G.
Part number: Airbag 9.41 H12 3730.
Revision: 91H12373 Serial Number: 0036M00AZST4
Encoding: 0033622
No errors found.
Address 16: Steering wheel
Label file: RKS\8E0-953-549.lbl
Part number: 8E0 953 549 Q
Component: Steering column module 0601.
Encoding: 04042
No errors found.
Address 17: Combination instrument
Label file: RKS\8E0-920-9xx-8EC.lbl
Part number SW: 8E0 920 931 M, HW: 8E0 920 931 M.
Component: KOMBI+WFS 3 H14 0110
Revision: 0110 Serial number: AUX6Z0F0180920
Encoding: 0006051
Operating number: WSC 48364 141 61370
No errors found.
Address 18: Auxiliary Heater
Label file: RKS\8E0-265-105.lbl
Part number: 8E0 265 105 H
Part: Gasoline auxiliary heater 0316.
Encoding: 00011
Operating number: WSC 65535
No errors found.
Address 37: Navigation
Label file: RKS\8E0-035-192-RNSE.lbl
Part number SW: 8E0 035 192 H, HW: 8E0 035 192 H.
Part number: RNS-E HIGH EU H72 0650.
Revision: 03S Serial Number: AUZBZ7F1026682
Encoding: 0309717
Operating number: WSC 06348 116 57033
No errors found.
Address 46: Comfort System
Label file: RKS\8E0-959-433-MAX.lbl
Part number: 8E0 959 433 CM
Component: Comfort Device TA7 4236.
Encoding: 07008
Part number: 8E1959801G
Component: Törsteuer.FS BRM 0706
Part number: 8E1959802G
Component: Törsteuer.BF BRM 0706
Part number: 8E0959801E
Component: Törsteuer.HL BRM 0606
Part number: 8E0959802E
Component: Törsteuer.HR BRM 0606
No errors found.
Address 55: Headlight range control. Label file: RKS\8P0-907-357.lbl
Part number: 8P0 907 357 F
Component: Dynamic Left Wheel Rail (LWR), H01 0010.
Revision: 00000001 Serial Number:
Encoding: 0000005
No errors found.
Address 56: Radio
Encoding: 0309717
No errors found.
Address 65: Tire pressure
Encoding: 0022222
"One error found:"
Error priority: 3
Error frequency: 1.
Lost Count: 40
Time: 0.
(no unit): 0.0
Voltage: 12.60 V
(no unit): 130.0
recognized
recognized
recognized
recognized
Address 76: Parking Assist
Label file: RKS\8E0-919-283-8EC.lbl
Part number SW: 8E0 919 283 E, Part number HW: 8E0 919 283 E.
Component: Parking assist system, 8 channels, part number H06 0010.
Revision: 00H06000 Serial Number: 00067802120604
Encoding: 0000114
No errors found.
Address 77: Telephone Label file: RKS\8P0-862-335.lbl
Part number SW: 8P0 862 335 M, Hardware part number: 8P0 862 335 M.
Component: FSE_255x BT H21 0200
Revision: 00000001 Serial Number: 00000000408983
Encoding: 0011801
No errors found.
"End"
Translated on 23-08-2026, 8:11.
Profile PM Garage |
10-04-2010, 20:46 Subject: Tire Pressure System Audi A4 B7 Door Control Unit |
Oops, I got it mixed up with the B8. On your car (B7), there shouldn't be address 19.
Have you tried simply removing the control unit for the tire pressure monitoring system?
Translated on 23-08-2026, 8:36.
VCDS-S
10-04-2010, 21:00 Subject: Tire Pressure System Audi A4 B7 Door Control Unit |
Not that bad  .
No, I haven't tried that yet...
Profile PM Garage |
VCDS-S
12-04-2010, 15:15 Subject: Tire Pressure System Audi A4 B7 Door Control Unit |
Okay, so the engine control unit (ECU) is located behind the left-side trim panel in the trunk, and to be honest, I really don't want to take everything apart; there must be another way  .
Profile PM Garage |
12-04-2010, 15:21 Subject: Tire Pressure System Audi A4 B7 Door Control Unit |
Well, the only error that occurs is that the tire pressure monitoring system control unit complains about the missing sensors... however, the error message (antenna) doesn't quite seem to fit, but that shouldn't affect the solution to the problem.
Therefore, I can hardly imagine that a control unit could simply "switch itself off," because what would be the point of installing it in the first place?
Just try disconnecting that part (disconnect the battery!) and see if everything works as expected afterwards.
Translated on 23-08-2026, 8:37.
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2403 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
12-04-2010, 21:28 Subject: Tire Pressure System Audi A4 B7 Door Control Unit |
Perhaps the component is individually protected, and removing that protection might help.
Translated on 23-08-2026, 8:38.
Profile PM Garage |
VCDS-S
13-04-2010, 15:01 Subject: Tire Pressure System Audi A4 B7 Door Control Unit |
guste100 wrote: | | Possibly, this part is individually secured, and removing that securing mechanism might help. |
Unfortunately, the following items are located on platform S17:
G397 sensor for rain and light detection.
Parking assist control unit J446.
Tire Pressure Monitoring System (TPMS) control unit J502.
Translated on 23-08-2026, 8:39.
Profile PM Garage |
VCDS-S
28-10-2010, 19:30 Subject: Tire Pressure System Audi A4 B7 Door Control Unit |
Hello everyone,
Now, another new error has appeared.
Please provide the German text you would like me to translate into English. I will only provide the translation without any explanations.
Address 46: Comfort system Label file: RKS\8E0-959-433-MAX.lbl
Component: Comfort device TA7 4236.
Encoding: 07008
Operating number: WSC 48364.
VCID: 7EF78C9E5085
"One error found:"
01331 - Door control unit, driver's side (J386)
80-00 - in single-wire operation.
(The door control unit was already replaced yesterday.)
Has anyone ever encountered this problem before and knows what's going on?
Translated on 23-08-2026, 8:41.
Profile PM Garage |
28-10-2010, 20:02 Subject: Tire Pressure System Audi A4 B7 Door Control Unit |
VCDS-S wrote: | 01331 - Door control unit, driver's side (J386)
80-00 - in single-wire operation | .
It's likely a broken cable inside the bellows. Please check it. MfG. Michael
Translated on 23-08-2026, 8:43.
Profile PM Garage |
