Fuel Injector Problems: Diagnosis & Repair
Rudolf
Post11-03-2003, 18:02    Subject: Fuel Injector Problems: Diagnosis & Repair Quote
'I have a 1995 Audi A6 with 140 horsepower. Lately, it's been throwing a check engine light intermittently (mostly during acceleration), and the engine control unit goes into limp mode. If I reduce the engine speed, the engine runs okay. When I read the error codes, it always shows the same error: an injector fault. I've tried everything I can think of. I've checked all the sensors – water temperature, air flow, fuel, etc. – and everything seems to be within the normal range. However, when I try to adjust the ignition timing, my actual value fluctuates significantly, by about plus or minus 2 degrees. This seems unusual, doesn't it? And if so, where could the problem be? I would be very grateful for any advice!'
Best regards,
Rudolf
PS: Has anyone had experience with tuning? I mean, manually editing the fields!
PS: Everything is still in its original condition for me at the moment!
Translated on 16-10-2026, 15:53.
Michael II
Post11-03-2003, 18:45    Subject: Fuel Injector Problems: Diagnosis & Repair Quote
Hello Rudolf,
What is the error code?
Tschüss
Michael II
Translated on 16-10-2026, 15:54.
Rudolf
Post12-03-2003, 19:10    Subject: SEO-Optimized Title: "Best German SEO Services" Quote
Okay, I tried it again. I drove the car until it triggered the error. But now it's giving me a slightly different error.
So, 00575, intake manifold pressure.
17-10 Rule Difference - Intermittent.
Does anyone have any advice on this?
He no longer experiences that other problem with ejaculation.
Thank you in advance.
Translated on 16-10-2026, 15:55.
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission Problems: Audi A4 01N AFN General Tips
No new posts Fixed Issue, New Problem Arises Diesel Engine Technology
No new posts WFS Issues: Troubleshooting and Solutions On-Board Diagnostics (OBD)
No new posts Graphics Card Issues: Troubleshooting Guide Transmission, Chassis, Body & Interior
No new posts DPF Problem: 2.0 TDI BPW A4 Diesel Engine Technology
