Golf 4 TDI 1.9 AXR engine, what is the voltage at the camshaft sensor?
martinfrs
Post31-10-2010, 16:50    Subject: Golf 4 TDI 1.9 AXR engine, what is the voltage at the camshaft sensor? Quote
Hello everyone!
Can someone please tell me how many volts should be present at the camshaft sensor?
Ignition on!!!?????????
Volkswagen Golf 4 TDI, AXR engine, manufactured in December 2001.
Thank you icon_question.gif.
Post31-10-2010, 18:07    Subject: Golf 4 TDI 1.9 AXR engine, what is the voltage at the camshaft sensor? Quote
5V, which is the standard voltage for most sensors. But please do not attempt to measure resistance with this device! Just tension, nothing else!
martinfrs
Post01-11-2010, 17:20    Subject: Golf 4 TDI 1.9 AXR engine, what is the voltage at the camshaft sensor? Quote
TDI-GTI-4-Motion wrote:
5V, which is the standard voltage for most sensors. However, do not perform any resistance measurements on this component! Only tension, nothing else!
Hey, thanks!
Now the only question is whether this part is broken again, and why they said that at VW.
It should be 12 volts, that's very strange. But okay, I'll move on for now.
Best regards from the Westerwald region.
No new posts Golf 5 / Audi A3 2004 BKC-Motor stirbt ab, startet nicht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Motor - Motor klappert, Leistungsmangel, Schwarzrauch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN Engine Glow Plug Fuse: What Size? Diesel Engine Technology
No new posts Only 8 volts on the N75, is that normal??? Diesel Engine Technology
No new posts Battery charging device with 12.5 volts? Diesel Engine Technology
No new posts 13.4 instead of 14.2 volts Gasoline Engine Technology
