Audi A4 2008 8K Underbody protection / Stone chip protection
chli1976
Karma: +185 / -0   Thank you, like it!
Post10-01-2011, 6:33    Subject: Audi A4 2008 8K Underbody protection / Stone chip protection Quote
Since newer cars have very little underbody protection/stone chip protection from the factory, I want to apply it myself. I once removed the fender liners, and there was nothing inside except for the primer coating.
What would you recommend I use? I've been looking at various products from Terroson, but there are so many different options for underbody protection/stone chip protection.
And how do I achieve that thick layer, like on the older models? I have a shotcrete gun.
VCDS
Translated on 06-07-2026, 10:29.
Karma: +1099 / -0   Thank you, like it!
Post10-01-2011, 8:51    Subject: Audi A4 2008 8K Underbody protection / Stone chip protection Quote
I would not apply conventional underbody protection to areas hidden by trim parts, such as wheel arch liners. If preservation or personal preference dictates otherwise in those areas, I would use Mike Sanders cavity wax. The material is processed at high temperatures, exhibits long-term creep, and also shrinks into joints.
I would choose conventional underbody protection (based on bitumen or wax) for areas prone to stone chipping. Wax has a degree of "self-healing" properties when exposed to heat, meaning smaller stone chips can close up on their own. However, with wax-based underbody protection, you need to regularly inspect it and potentially reapply it. Compared to bitumen-based underbody protection, the advantage of wax is that you can easily see any changes to the bodywork (e.g., rust formation) and react sooner. While bitumen is more mechanically resistant, it can hide corrosion and other issues for quite some time.
Translated on 06-07-2026, 10:30.
chli1976
Post10-01-2011, 13:19    Subject: Audi A4 2008 8K Underbody protection / Stone chip protection Quote
I spoke with a VW mechanic/painter, and he told me that some Tourans have already been treated for rust formation on the underbody. That's why I'd like to apply a preventative corrosion protection, as there is currently no corrosion protection on the undercarriage of my Audi, even underneath the plastic covers.
VCDS
Translated on 06-07-2026, 10:32.
Post10-01-2011, 13:43    Subject: Audi A4 2008 8K Underbody protection / Stone chip protection Quote
Then remove the trim pieces, clean them thoroughly, and let them dry. Once you've decided on the preservative to use, apply it, let it air dry, and then reattach the trim pieces. I wouldn't use any bitumen behind the trim pieces. Reasons are listed above...
Of course, after each winter, these covers should be removed again, and the winter grime (including any salt residue) should be washed off. After a visual inspection, it is then determined whether any further work is needed, or whether one can simply appreciate the good state of preservation of the conserved areas and take no further action.
Translated on 06-07-2026, 10:33.
Deus Violentia
Post11-01-2011, 9:52    Subject: Audi A4 2008 8K Underbody protection / Stone chip protection Quote
@Hat Fahrer: If you properly seal a car component with bitumen, you won't experience any rust issues with a 2008 Audi. Otherwise, you are correct.
BKD GRF
AHF EBF
Translated on 06-07-2026, 10:34.
chli1976
Post11-01-2011, 21:23    Subject: Audi A4 2008 8K Underbody protection / Stone chip protection Quote
And how is the bitumen applied to achieve such a layer thickness? Is it applied by painting?
VCDS
olli
Karma: +46 / -0   Thank you, like it!
Post12-01-2011, 0:35    Subject: Audi A4 2008 8K Underbody protection / Stone chip protection Quote
I wouldn't use anything with bitumen in it; it becomes brittle and cracks over time. In the past, preservatives were made from PVC, which was almost permanently elastic. It likely resolved itself today due to the issue of disposal problems/take-back obligations.
I can only say good things about Permafilm based on my experience with my older cars. The product is relatively hard, making it suitable for areas prone to spraying, and it's essentially transparent; you can see through it. It also remains permanently elastic (at least, that's what 8 years of personal testing has shown). And if even Fiat body panels, which are almost four times older, don't corrode further, then the product must be quite good.
Best regards from Berlin,
olli
A6 CANA/JME /
Ex-A6 AEL
Translated on 06-07-2026, 10:35.
Stummel
Post12-01-2011, 0:49    Subject: Audi A4 2008 8K Underbody protection / Stone chip protection Quote
Is Permifilm more like a 'lacquer' or just a solid wax or something?
How to process?
Translated on 06-07-2026, 10:36.
olli
Post12-01-2011, 20:31    Subject: Audi A4 2008 8K Underbody protection / Stone chip protection Quote
Permafilm is paintable, and likely sprayable, but it hardens slightly (becomes less sticky) and doesn't crack easily at higher outdoor temperatures.
Just Google it using the keywords "Fluidfilm" or "Permafilm".
olli
A6 CANA/JME /
Ex-A6 AEL
Translated on 06-07-2026, 10:37.
chli1976
Post26-01-2011, 7:10    Subject: Audi A4 2008 8K Underbody protection / Stone chip protection Quote
I once inquired about a corrosion protection product called Permafilm for the undercarriage.
I received this response.
"For the underbody, either Fertan UBS220 (gold-brown, transparent) or Elaskon 2000ML (whitish, transparent) should be used. The idea behind using a product like Perma-Film is fundamentally correct, however, the quality and durability have noticeably decreased in recent times, making it more prone to becoming brittle." Of the two underbody protection waxes mentioned, one is clearly the better choice.
VCDS
Translated on 06-07-2026, 10:38.
No new posts Upgrade of MMI Basic Sound System Audi A6 4F up to KW35/2008 Troubleshooting & Guides
No new posts Ford Fiesta Temperature Sensor: Problems & Fixes General Tips
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Retrofitting hands-free system for Audi A4 8K, year 2008 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi A4 8K, year 2008, engine code CAGA - Engine breather... Diesel Engine Technology
No new posts PQ35 Underbody Protection Transmission, Chassis, Body & Interior
No new posts Recommendation and Source: Underbody Protection Transmission, Chassis, Body & Interior
