VAG 2.0 TDI: Longitudinal vs. Transverse Engine Installation
dokatoto
Post09-12-2010, 7:55    Subject: VAG 2.0 TDI: Longitudinal vs. Transverse Engine Installation Quote
Do the VAG engines differ in their engine blocks?
Specifically, will I receive a BKD instead of a BLB/BRE being installed?
Do I find the corresponding mounting holes for the engine, and are only the attached components different?
Thank you and best regards.
Toto.
Translated on 22-10-2026, 18:36.
Stummel
Post09-12-2010, 23:01    Subject: VAG 2.0 TDI: Longitudinal vs. Transverse Engine Installation Quote
The 170 hp models have a set of balance shafts in the oil pan when installed longitudinally... so something must be different.
Translated on 22-10-2026, 18:37.
Post10-12-2010, 8:55    Subject: VAG 2.0 TDI: Longitudinal vs. Transverse Engine Installation Quote
Not quite.
The 3C is the only cross-country 170 model that also has an automatic weapon system.
That, at the very least, distinguishes the BMR (3C with) from the BMN (the others, transverse without).
Translated on 22-10-2026, 18:38.
Stummel
Post10-12-2010, 22:30    Subject: VAG 2.0 TDI: Longitudinal vs. Transverse Engine Installation Quote
Okay, that's reassuring. I've heard that the oil pressure relief valve sometimes fails, and because the oil pump is connected to it, this often leads to engine damage. I'm glad that can't happen in the 170hp PD Touran.
No new posts Timing belt replacement for transversely mounted PD engine Troubleshooting & Guides
No new posts Welded Rust Repair: Fixing Longitudinal Beams Transmission, Chassis, Body & Interior
No new posts Differences ESP at AAZ: 028 130 107 R vs 028 130 107 K Diesel Engine Technology
No new posts PDE vs. 2.0 TDI: Differences Explained Diesel Engine Technology
No new posts 1V - Differences from JR, Differences between RA and SB Diesel Engine Technology
