teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
14-12-2010, 18:23 Subject: Polo AMF Exhaust Manifold Gasket Replacement |
Hello, how much time should I allocate for replacing the exhaust manifold gasket? I have a situation where the right driveshaft is completely covered in black soot, extending all the way up behind the turbo to the exhaust manifold. Therefore, I suspect the gasket is the weak point.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 29-10-2026, 14:19.
Profile PM Email Garage |
14-12-2010, 21:58 Subject: Polo AMF Exhaust Manifold Gasket Replacement |
My rep program says 2.9 hours.
I have no idea if it's actually possible to create. I've never done anything like it before.
Translated on 29-10-2026, 14:20.
Profile PM Garage |
14-12-2010, 22:09 Subject: Polo AMF Exhaust Manifold Gasket Replacement |
Sure, thanks.
So, I was thinking about removing the intake pipes and manifolds, the turbo and exhaust manifold, and the EGR pipe.
Do I need to add more? There's hardly any space.
Retract the tailpipe... or should I just keep sending it, because the studs tend to break off?
14-12-2010, 22:36 Subject: Polo AMF Exhaust Manifold Gasket Replacement |
Which engine? Are you sure the EGR pipe hasn't broken?
Translated on 29-10-2026, 14:21.
Profile PM WWW Garage |
14-12-2010, 22:59 Subject: Polo AMF Exhaust Manifold Gasket Replacement |
Hello Rainer: AMF engine - not my Polo.
The AGR pipe was replaced just last year.
It's highly unlikely that it would blow all the way down to the right drive shaft near the turbo.
Translated on 29-10-2026, 14:22.
14-12-2010, 23:03 Subject: Polo AMF Exhaust Manifold Gasket Replacement |
Okay, I've experienced this issue myself on two vehicles with 3-cylinder engines.
14-12-2010, 23:30 Subject: Polo AMF Exhaust Manifold Gasket Replacement |
Sure, but that came with a loss of power. This year, I would guess it's more likely to result in a slightly sluggish start or delayed turbo boost.
I only saw the excessive soot during the oil change, which then led to questions about the amount of work involved and the associated costs.
