W-Clamp Retrofit for Valeo Lima Brakes
dieter
Karma: +13 / -0   Thank you, like it!
Post18-03-2003, 10:57    Subject: W-Clamp Retrofit for Valeo Lima Brakes Quote
Hi there,
We put a VW T3 bus with an AHU engine converted to mechanical injection into operation over the weekend. Unfortunately, the engine has a Valeo-Lima starter without the W-terminal. Since the engine control unit is missing, a gasoline-specific diesel injection module (DZM) cannot be used either.
I opened the alternator housing to install the W-terminal and was surprised to see 6 (double) connections coming from the stator. I can't quite understand the wiring diagram. I tapped into one of them anyway, but it's not working correctly. The digital volt meter (DVM) shows nothing at idle and displays too much voltage when I give it gas. Furthermore, the readings also change depending on the load on the alternator.
Now I'm looking for a wiring diagram for the Lucas ignition system (or "lima") and/or some tips on what can be done with it.
Greetings from Hamburg.
dieter
T3 Syncro, 16" AFN.
Translated on 23-09-2026, 19:32.
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts FSE Premium Retrofit for Passat, Golf, Tiguan Troubleshooting & Guides
No new posts Erratic behavior in low-speed operation - is the to blame? Diesel Engine Technology
No new posts TDI B4: Upgrade GRA (1992) Diesel Engine Technology
No new posts Retrofit BT for 9ZF Transmission Transmission, Chassis, Body & Interior
No new posts VW: Retrofitting LDA (Local Differential Analyzer) Diesel Engine Technology
