V6 TDI: White Smoke from Oil Filler? Is it Normal?
exciter
Registered VCDS User
Post23-05-2011, 20:05    Subject: V6 TDI: White Smoke from Oil Filler? Is it Normal? Quote
Hey,
I've noticed that when the oil filler cap is removed, there's a whitish vapor coming from the oil filler neck.
I don't have any pressure, the lid just sits on top and doesn't move.
However, if the opening is open, it will emit white steam.
The steam smells like oil - it's been like that since I've owned the car.
I'm not going to let that cool down.
Are these oil components, or is it water that's evaporating, or is it something mechanical?
The engine is a 2.5 V6 TDI with the engine code BDG.
"LG" is an abbreviation for "Liebe Grüße," which means "Best regards" or "Best wishes" in English.
Translated on 19-09-2026, 9:26.
Tagessuppe
Karma: +36 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post24-05-2011, 18:34    Subject: V6 TDI: White Smoke from Oil Filler? Is it Normal? Quote
Oil mist.
It's normal.
Translated on 19-09-2026, 9:27.
No new posts Dampf aus Klimaanlage Transmission, Chassis, Body & Interior
No new posts Tuning Box: White Smoke from Full Throttle? Diesel Engine Technology
No new posts White smoke after warm start 2.0 PD TDI Diesel Engine Technology
No new posts Radiator Fan Runs at Level 2 - Normal? Diesel Engine Technology
