Boost pressure differential
solarplexus
Post23-01-2011, 7:31    Subject: Boost pressure differential Quote
I'm now also experiencing the problem with the pressure difference in the turbocharger system – the boost pressure is too high!
This error only occurs for me when I'm driving on the highway!
I've rarely encountered this problem before.
The difference from the current situation is that in emergency mode, the boost pressure used to remain at 0.6 bar.
However, during the current test runs, it remains at 0.9 bar!
Where should I start troubleshooting?
VW Golf IV Estate - AGR engine.
Translated on 16-07-2026, 14:11.
Post23-01-2011, 11:14    Subject: Boost pressure differential Quote
The errors "intake manifold pressure control difference" and "boost pressure too high" are two different things.
Poste mal den Fehlerscan (VCDS Lizenz Nr. nicht vergessen, dto. (Search function).
"vg" translates to "very good" in English.
Translated on 16-07-2026, 14:12.
solarplexus
Post23-01-2011, 16:30    Subject: Boost pressure differential Quote
Error code: 17965 - Turbocharger pressure control - Limit exceeded.
Where is the VCDS license number located?
Translated on 16-07-2026, 14:13.
Post23-01-2011, 19:08    Subject: Boost pressure differential Quote
solarplexus wrote:
wo steht die VCDS-Lizenznummer?
On the "About..." screen in VCDS.
No new posts Turbocharger Pressure Difference Log Upload
No new posts Boost Pressure Issues: Intermittent Problems? Diesel Engine Technology
No new posts Passat AHU: Turbocharger Boost Pressure Too High On-Board Diagnostics (OBD)
No new posts AHU: Charge Pressure Difference - Troubleshooting Guide On-Board Diagnostics (OBD)
