Renault 1.9 dCi Crankshaft - Replacement
schlauchdruide
Post16-01-2011, 18:04    Subject: Renault 1.9 dCi Crankshaft - Replacement Quote
I just have a quick question.
Does anyone know if the crankshaft of the F9Q engine (1.9 dci) can be ground down, and if so, what tolerances are possible?
The Renault dealer only finds one part number in their spare parts catalog for the bearing shells.
Translated on 25-10-2026, 0:46.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post16-01-2011, 18:38    Subject: Renault 1.9 dCi Crankshaft - Replacement Quote
Actually, it's a question about the pistons, isn't it?
Google, search time: 0.11 seconds.
http://www.google.de/search?hl=de&client=firefox-a&hs=rJX&rls=org.mozilla:de:official&&sa=X&ei=YywzTf-rAofLswbc2smMCg&ved=0CBwQBSgA&q=F9Q+Kolben+%C3%9Cberma%C3%9F+Gaenssle&spell=1
If you get pistons, then honing them also makes sense.
Just give them a call. The phone number is 089 886109.
1936ccm: Pistons with oversized rings, pins, and retaining clips.
DZylStd KH ÜH VT MT GL SiRi KoBo Form
0.50 mm 80.01 47.06 -0.75 17.8 77.40 28.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 25-10-2026, 0:47.
schlauchdruide
Post16-01-2011, 19:51    Subject: Renault 1.9 dCi Crankshaft - Replacement Quote
'I'm referring to the crankshaft. There's bearing damage in the first cylinder, with an out-of-spec clearance of 4/100 - 5/100. The dealer only has one part number in their catalog for the bearing shells and can only order that one. If there were oversized bearings, they would have a different part number. So, the Renault dealer couldn't help me because, according to them, they always sell complete engine blocks and don't do any repairs.'
Translated on 25-10-2026, 0:48.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post16-01-2011, 20:00    Subject: Renault 1.9 dCi Crankshaft - Replacement Quote
Ah, sorry, I missed the KW.
Engine mechanics are most likely to have the answer.
Translated on 25-10-2026, 0:49.
schlauchdruide
Post16-01-2011, 20:06    Subject: Renault 1.9 dCi Crankshaft - Replacement Quote
OK.
I'll see if any of them can make me happy.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post16-01-2011, 20:18    Subject: Renault 1.9 dCi Crankshaft - Replacement Quote
Please provide the exact data for "1810 CCM," including horsepower and year of manufacture.
I found an excess of 0.25 in one case.
GLYCO H098/5, in preparation +0.25, main warehouse.
Federal Megul +32 (0)345 19 711
B-2630 Aartselaar.
http://autoteile-online.biz/auto/renault/4724/laguna_ii_grandtour_kg0_1_1,9_dci_motor_kurbelwellenlager_24202.shtml
Translated on 25-10-2026, 0:50.
schlauchdruide
Post16-01-2011, 20:31    Subject: Renault 1.9 dCi Crankshaft - Replacement Quote
Renault Megane II
Engine: Gasoline, 05/04, 88 kW, 1870 ccm, Engine code: F9Q 800.
Translated on 25-10-2026, 0:51.
Diesel_Rudi
Post16-01-2011, 21:14    Subject: Renault 1.9 dCi Crankshaft - Replacement Quote
Of course, the crankshaft bearings can be machined. However, you won't be able to get undersized bearings through the original equipment manufacturer (OEM) supply chain. The size reduction is always in increments of 0.25mm. The corresponding bearings are available through your engine parts supplier.
schlauchdruide
Post16-01-2011, 22:04    Subject: Renault 1.9 dCi Crankshaft - Replacement Quote
Thank you, now I can sleep soundly.
Translated on 25-10-2026, 0:52.
schlauchdruide
Post18-01-2011, 22:26    Subject: Renault 1.9 dCi Crankshaft - Replacement Quote
I visited a cylinder grinding shop today, and as you mentioned, the shaft can be ground down to a tolerance of 0.75mm undersize.
Thank you for the answers.
schlauchdruide
Post22-01-2011, 8:25    Subject: Renault 1.9 dCi Crankshaft - Replacement Quote
I found a website that lists virtually all crankshaft bearings from almost every manufacturer, with all sorts of possible dimensions. If you're looking for something specific, you're likely to find it here.
http://www.king-bearings.com/cat/panel/pan1945.htm
vwSchrauber
Post24-01-2011, 13:32    Subject: Renault 1.9 dCi Crankshaft - Replacement Quote
rufe halt mal dort an. Tel. 089 886109
Oversized pistons with rings, pins, and retaining clips, 1936ccm.
DZylStd KH ÜH VT MT GL SiRi KoBo Form.
We've encountered this before. The problem with the oversized pistons was the nozzles for the piston bottom cooling. They are not available on the open market, and are only available from the Eastern European or Russian market. With a 5-week waiting time icon_rolleyes.gif.
Connecting rod bearing bushings are completely unavailable.
Translated on 25-10-2026, 0:54.
schlauchdruide
Post24-01-2011, 21:24    Subject: Renault 1.9 dCi Crankshaft - Replacement Quote
Thank you for the tip.
Translated on 25-10-2026, 0:55.
No new posts Renault Kangoo Crankshaft: Problems & Solutions Diesel Engine Technology
No new posts Crankshaft Vibration Dampers Diesel Engine Technology
No new posts AEL Crankshaft Counterweight - Replacement Diesel Engine Technology
No new posts AAT Crankshaft Material Diesel Engine Technology
