Golf 4 1.6 constantly shaking/vibrating
GTI
Post26-01-2011, 15:27    Subject: Golf 4 1.6 constantly shaking/vibrating Quote
My friend is having the following problem:
When driving at a constant speed (e.g., 90 km/h), there is a noticeable jerking or shaking. We did a diagnostic run together using VAG-COM, and I detected misfires on cylinder 2, and occasionally also on cylinder 3.
Unfortunately, the engine doesn't have the ignition coils that I'm familiar with, like those found in the 16V model.
Where would be the best place to start looking for parts or to begin the repair process now? Replace ignition coil and cable? icon_rolleyes.gif
The vehicle is a Golf 4 1.6 APF, manufactured in 2000.
Tiguan Life Bj 2014 7-Gang DSG 2,0 TDI 4-Motion 177PS
Back to top Profile PM Email
GTI
Post26-01-2011, 19:09    Subject: Golf 4 1.6 constantly shaking/vibrating Quote
Okay, let me rephrase that.
Can misfires detected by the engine control unit also be caused by, for example, faulty fuel injectors?
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post26-01-2011, 21:53    Subject: Golf 4 1.6 constantly shaking/vibrating Quote
Checking spark plugs, checking ignition cables, ignition coils or distributor... I have no idea what you're dealing with.
It is possible to see values related to the fuel injectors in certain diagnostic data.
And before anyone else answers, the VCDS license is missing icon_cool.gif.
kuestenkuddel
Post26-01-2011, 22:00    Subject: Golf 4 1.6 constantly shaking/vibrating Quote
Hi.
Try swapping injector 1 with injector 2, and after the next test run, you'll know what's going on.
Best regards, Kurt.
GTI
Post27-01-2011, 11:18    Subject: Golf 4 1.6 constantly shaking/vibrating Quote
klahaui wrote:
Checking spark plugs, checking ignition cables, checking ignition coils or distributor... I have no idea what you're dealing with.
I have entered my VCDS license information in my profile... it seems like it still needs to be verified?
We could try swapping the injector valves around to see if that makes a difference. Thank you in advance.
Karma: +1102 / -0   Thank you, like it!
Post27-01-2011, 11:39    Subject: Golf 4 1.6 constantly shaking/vibrating Quote
Are the spark plugs, candles, and ignition coils okay? What is the engine code? Everything seems to be in pretty good, diagnosable condition. Perhaps someone knows what you might be able to log there.
Turbinchen
Karma: +76 / -0   Thank you, like it!
2014 Audi A4 Avant
Post27-01-2011, 12:23    Subject: Golf 4 1.6 constantly shaking/vibrating Quote
To answer your question, yes, misfires can occur in 1.6-liter engines due to the injectors. This shouldn't be a rare occurrence.
klahaui
Avatar-klahaui
Post27-01-2011, 15:06    Subject: Golf 4 1.6 constantly shaking/vibrating Quote
As I mentioned, check the error memory. And before you replace anything, make sure to inspect it carefully; it's possible a badger gnawed on the spark plug cable and damaged the insulation, causing sparks to jump out.
GTI
dieselschrauber likes this.
Post30-01-2011, 20:02    Subject: Golf 4 1.6 constantly shaking/vibrating Quote
So, there were no error codes stored in the system's memory. I could only read the glitches from the data blocks.
Yesterday, we tried to fix the car. First, we used a pressure washer on the engine, which made it very difficult to drive. Then, we replaced the seals on the fuel injectors and swapped them around. We also installed new spark plug wires, a new intake manifold gasket, and a new ignition coil. The ignition coil was likely the culprit as well, because the casing was cracked and a contact was completely rusted/oxidized.
Thank you for your tips! I enjoy being here.
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dashboard warning light for airbag "OFF" is constantly il... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf ALH Relay: Always On in Cold Weather Diesel Engine Technology
No new posts Golf 4 TDI jerks/shudders Diesel Engine Technology
No new posts Golf V BKC engine shakes/vibrates until approximately 60°C Diesel Engine Technology
This topic is locked, you cannot edit or reply. Golf TDI Shakes at Partial Load Only Diesel Engine Technology
