teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
19-02-2011, 11:04 Subject: DPF Loose Parts: Buy Now & Save! |
Hello, I'm currently trying to replace the third temperature sensor on a 2006 T5 with a 130 hp, 2.5 TDI engine (AXD code).
Now the blockage was cleared – the cause was loose honeycomb pieces inside the pipe.
| Description: |
| DPF 130 PS, 2,5tdi, T5, AXD |
| File size: |
852.66 KB |
| Viewed: |
4645 times |
| Description: |
| File size: |
675.68 KB |
| Viewed: |
3396 times |
| Description: |
| Verbogene Temperatursonde mit verkeiltem Wabenstück im DPF |
| File size: |
634.33 KB |
| Viewed: |
2360 times |
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 06-08-2026, 16:06.
Profile PM Email Garage |
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
19-02-2011, 12:26 Subject: DPF Loose Parts: Buy Now & Save! |
Interesting, it looks like there might be a material defect or excessive overheating. Were you able to determine the cause of why it detached?
NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 06-08-2026, 16:07.
19-02-2011, 12:33 Subject: DPF Loose Parts: Buy Now & Save! |
Yes, that's still my question: Is the overheating caused by regeneration or by driving?
He's more of a cautious driver; not someone who speeds or overloads trailers.
If he weren't already so old, I would try to get something for free out of goodwill.
| Description: |
| File size: |
852.66 KB |
| Viewed: |
1691 times |
20-02-2011, 20:56 Subject: DPF Loose Parts: Buy Now & Save! |
Does anyone have any suggestions as to what might be the cause?
Just replace it with a new one and that's it?
I would simply type "shaken."
Translated on 06-08-2026, 16:08.
BM Profi-Schrauber
Joined: 12/07/2005 Posts: 1857 Karma: +8 / -0 Location: Nähe Düsseldorf
20-02-2011, 21:13 Subject: DPF Loose Parts: Buy Now & Save! |
Quote: | Does anyone have any suggestions as to what might be the cause?
I would simply type "shaken". |
Yes, the Lopez effect.
If you take a closer look at all these new designs, it's truly surprising that they actually work.
In my opinion, either Toys"R"us or Matchbox.
3B5 AJM
Translated on 06-08-2026, 16:09.
20-02-2011, 21:24 Subject: DPF Loose Parts: Buy Now & Save! |
OK, thank you BM, then just do it again.
Translated on 06-08-2026, 16:10.
BM Profi-Schrauber
20-02-2011, 22:00 Subject: DPF Loose Parts: Buy Now & Save! |
teileklaus wrote: | OK, thank you BM, then just do it again.  |
You could check with the  to see if it's a known issue.
3B5 AJM
20-02-2011, 22:33 Subject: DPF Loose Parts: Buy Now & Save! |
Okay, I'll take care of it when I place the order. Thanks, BM.
mserge Schrauber
Joined: 06/20/2005 Posts: 923 Karma: +6 / -0 Location: Luxemburg
21-02-2011, 10:53 Subject: DPF Loose Parts: Buy Now & Save! |
Is the engine perhaps performance-enhanced? If so, I could understand that...
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 06-08-2026, 16:11.
21-02-2011, 16:21 Subject: DPF Loose Parts: Buy Now & Save! |
Hello, the DPF is supposed to cost 1140 plus  .
"@mserge It hasn't been performance-tuned, and it's being driven responsibly."
mserge Schrauber
21-02-2011, 16:45 Subject: DPF Loose Parts: Buy Now & Save! |
Remove the broken part and continue  .
Deus Violentia Schrauber
22-02-2011, 16:38 Subject: DPF Loose Parts: Buy Now & Save! |
Simply fill the casing with NASA high-temperature expanding foam, which also filters; the control unit probably won't notice  .
BKD GRF
AHF EBF
Translated on 06-08-2026, 16:12.
22-02-2011, 17:56 Subject: DPF Loose Parts: Buy Now & Save! |
Are differential pressure sensors not included either?
22-02-2011, 18:06 Subject: DPF Loose Parts: Buy Now & Save! |
I hope you realized that was a joke, right?
BKD GRF
AHF EBF
22-02-2011, 21:00 Subject: DPF Loose Parts: Buy Now & Save! |
No, not quite like that; there are people who rephrase "Ausräumen" in different ways.
Yes, I am currently looking for a replacement.
PD90 Blaumann
Registered VCDS User
26-02-2011, 7:34 Subject: DPF Loose Parts: Buy Now & Save! |
Well, almost everything has already been said, but maybe here are a few more details:
- It's more likely due to thermal overload, but not during Normal Reservoir Mode (NRM), but rather when Active Reservoir Generation (RGN) is engaged.
In NRM, the maximum temperature is approximately 850°C (at the nominal point, more likely 820°C), resulting in about 650°C before the Diesel Particulate Filter (DPF).
=> No problem for the DPF under the prevailing mass flow conditions...
- However, if the filter is full/overloaded and the regeneration control unit (RGN) is triggered, the target temperature before the diesel particulate filter (DPF) is still around 650°C, but due to the exothermic reaction (caused by the stored soot mass), local temperatures within the DPF can quickly reach 1000°C or more.
Then, ideally, the appropriate driving maneuver ("drop to idle"), and the oxygen boost further increases the temperatures in the DPF.
=> Large thermal stresses can occur, especially at the "bonding points" of the square filter blocks, and the filter can be damaged by anything from microscopic cracks to complete failure, as you have experienced.
"Swipe tests" are therefore performed in the OEM's production lines. For example, at each stop before the final inspection (FSP), a tissue is used to wipe the inside of the nozzle once.
"gray scale" documented.
White = everything is perfect.
gray = increased attention needed; micro-cracks may already be present.
black = filter breakage (like yours).
"Since dummy vehicles are sometimes used in the testing process, which can lead to excessive soot buildup throughout the entire aftertreatment system, including the diesel particulate filter (DPF), a swab test is sometimes performed at the outlet of the DPF during filter weighing (which is necessary for creating a loading/burn-off model)."
You're basically right up front in the first row...
Unfortunately, filter breakage seems to be a relatively common issue with the T5 model.
Okay, here's the translation:
"Guys, with older vehicles, we're lucky to see them spewing smoke like crazy, but with these DPFs, we can kiss that visual indicator goodbye!"
=> It will be interesting to see what happens when the DPF systems start getting old!
Translated on 06-08-2026, 16:15.
