Blinking Relay Noise: Causes & Fixes
uhrmeister
Post14-02-2006, 16:30    Subject: Blinking Relay Noise: Causes & Fixes Quote
3BG, AVF engine, year 2001, 190,000 km.
The following problem:
More and more often, the turn signal relay rattles wildly (even though the vehicle isn't actually blinking).
That's annoying. Replacing it with a new relay only provided temporary relief.
It's worst when it's cold and damp. If you drive for a long time with the heater on, it gradually stops.
I've already tried spraying wax protectant on the pins of the flasher relay to keep moisture away, but the effect was only temporary.
Does anyone know about this problem and can help?
Bernhard.
Translated on 04-10-2026, 20:04.
pax
Avatar-pax
2000 Volkswagen Passat
Post15-02-2006, 8:48    Subject: Blinking Relay Noise: Causes & Fixes Quote
uhrmeister wrote:
More and more often, the turn signal relay rattles wildly (even though the vehicle doesn't actually blink).
Does this happen when the turn signal lever is activated, or randomly? In the first case, consider the steering column switch.
Bye.
peace
Translated on 04-10-2026, 20:05.
uhrmeister
Post15-02-2006, 17:03    Subject: Blinker Relay: Buy Online | Best Prices Quote
The rattling sound occurs after you've blinked once, but not immediately after.
A slight wobble in the steering column lever cannot cause the rattling sound; instead, it usually starts like this:
Just turn it on sometime.
I've already soldered a flyback diode to the relay coil, though.
Impact.
Translated on 04-10-2026, 20:06.
bloesch
Post15-02-2006, 18:10    Subject: Blinking Relay Noise: Causes & Fixes Quote
Based on my experience with Audis, it's usually (90% of the time) the relay in the hazard light switch.
If not, the problem is usually resolved by replacing the turn signal lever.
Translated on 04-10-2026, 20:07.
Post15-02-2006, 21:01    Subject: Blinking Relay Noise: Causes & Fixes Quote
The rattling sound often comes from a faulty hazard light switch.
Actually, it's a well-known problem.
uhrmeister
Post31-05-2006, 11:28    Subject: Blinking Relay Noise: Causes & Fixes Quote
Thanks for the information. The problem has been resolved after replacing the steering column switch.
Inside the steering column lever, a conductive strip is located on a flat ribbon cable, which sharply curves around...
It's bent at a corner and eventually breaks off.
Bernhard.
Translated on 04-10-2026, 20:08.
Post04-02-2011, 20:32    Subject: Blinking Relay Noise: Causes & Fixes Quote
Ha, now I'm experiencing that interesting phenomenon too. What exactly is it? Is it the steering column switch, or just the turn signal switch? I'm leaning towards the latter.
Does anyone have any reliable information?
Post04-02-2011, 20:46    Subject: Blinking Relay Noise: Causes & Fixes Quote
Translated on 04-10-2026, 20:09.
Octavia_4x4
Post04-02-2011, 21:14    Subject: Blinking Relay Noise: Causes & Fixes Quote
Okay, I understand. Please provide the text you would like me to translate from German to English.
Proof can be found here:
The A3, Octavia, Golf IV, and Passat models share the same steering column switches, which have the same quality issue with the sliding contact.
TDI-GTI-4-Motion wrote:
Translated on 04-10-2026, 20:10.
Post04-02-2011, 21:17    Subject: Blinking Relay Noise: Causes & Fixes Quote
Octavia_4x4 wrote:
The A3, Octavia, Golf IV, and Passat have the same steering column switches - with the same quality problem at the friction surface.
Not only there, but I've also experienced this multiple times with the A4 and A6.icon_wink.gif
Octavia_4x4
Post04-02-2011, 21:22    Subject: Blinking Relay Noise: Causes & Fixes Quote
Yes, I know, we even had that issue with our V8. It was more about the fact that the steering column switches are identical, meaning they have the same part number.
"Unfortunately, one of the tires on our bus is now in really bad condition and makes a terrible noise."
Translated on 04-10-2026, 20:11.
Post05-02-2011, 10:51    Subject: Blinking Relay Noise: Causes & Fixes Quote
"Thank you!"
Octavia_4x4
Post07-02-2011, 21:52    Subject: Blinking Relay Noise: Causes & Fixes Quote
Here's my tip: If the left lever with the GRA (likely referring to a control panel) is defective, you can buy the one from a Skoda Superb. It has a simple hourglass symbol on it, but it's cheaper and compatible.
Translated on 04-10-2026, 20:12.
Post09-02-2011, 19:03    Subject: Blinking Relay Noise: Causes & Fixes Quote
Great tip, I'll order it! Thanks.
Octavia_4x4
Post10-03-2011, 19:59    Subject: Blinking Relay Noise: Causes & Fixes Quote
uhrmeister wrote:
Thank you for the information; after replacing the steering column switch, the problem has been resolved.
Bernhard
"Not entirely correct; the conductor track is for the cruise control buttons... the turn signal uses solid copper contact strips, as you can see in the link above and in my detailed photos of the disassembled lever."
No new posts Audi A6: How to Replace Turn Signal Relay Diesel Engine Technology
No new posts Fuel injection pump rattles Diesel Engine Technology
No new posts Audi B6 1.8T rattles Gasoline Engine Technology
