Nm: 285 vs. 310 - Which is Better?
Harry
Post22-03-2003, 21:48    Subject: Nm: 285 vs. 310 - Which is Better? Quote
Hello.
I read in a thread that the TDI engine with 85 kW supposedly has 285 Nm of torque with a 5-speed gearbox and 310 Nm with a 6-speed gearbox.
That would mean that VW ripped me off... I have a 6-speed transmission, but only 285 Nm of torque...
Translated on 18-10-2026, 8:35.
kenny
Post23-03-2003, 1:29    Subject: Nm: 285 vs. 310 - Which is Better? Quote
The maximum torque depends on the engine code, but not necessarily on the transmission.
AJM 285 Nm.
AUY 310 Nm
According to my records, at least.
I can't say whether the AJM engine with a 6-speed transmission can produce 310 Nm of torque. It probably wouldn't make much of a difference anyway! Besides, most TDI engines tend to have quite a wide range of possible outputs.
Translated on 18-10-2026, 8:37.
DaBibo
Post24-03-2003, 10:17    Subject: SEO-Optimized Website Design: Tips & Tricks Quote
I'm driving an AJM MJ01, and it's showing over 300 Nm when checked with a VW diagnostic tool.
Translated on 18-10-2026, 8:38.
Juergen
Post24-03-2003, 10:32    Subject: Nm: 285 vs. 310 - Which is Better? Quote
According to information from Audi (I don't know if VW does the same), models with front-wheel drive generally have a maximum torque of 285 Nm, while models with Quattro all-wheel drive have 310 Nm or more.
Best regards, Jürgen.
DaBibo
Post24-03-2003, 10:36    Subject: SEO: Best German to English Translation Services Quote
Could this possibly be related to the change to the MJ01? I also have a 90,000 km timing belt interval with a wider timing belt...
Translated on 18-10-2026, 8:39.
Harry
Post24-03-2003, 19:58    Subject: Nm: 285 vs. 310 - Which is Better? Quote
It might make sense that vehicles with 4Motion would receive the 310 tires to compensate for higher losses.
'But I had mine tested on a Bosch dynamometer - I don't think it really matters whether it's 310 or 'just' 285; my car produced around 88 kW anyway.'
Oh, by the way - there was a thread about corrosion on the rear window guide (the triangular piece, for 5-door models).
I washed my car today, and guess what, it's starting to happen to mine too... icon_eek.gif
Greetings.
Harry.
Translated on 18-10-2026, 8:40.
zzzZZ
Post25-03-2003, 7:38    Subject: Nm: 285 vs. 310 - Which is Better? Quote
Well,
My 1996 Golf 3 is also starting to rust, but it's happening on the A-pillar.
In the first year, the windshield was replaced, and I really believe now that they messed something up while doing it icon_evil.gif.
Of course, the warranty against rust has expired 5 months ago.
With my luck, the windshield probably has to come out so I can properly check exactly where the rust has spread icon_evil.gif.
Translated on 18-10-2026, 8:41.
Harry
Post27-03-2003, 11:34    Subject: Nm: 285 vs. 310 - Which is Better? Quote
Okay, so I was at my mechanic's shop.
'I was initially informed that the 'rust protection' warranty does not apply to attachments. The guide plate is one such attachment.'
However, the gentleman kindly contacted the manufacturer, as this issue had been noticed before. He immediately knew which part I was referring to.
Let's see icon_confused.gif.
Translated on 18-10-2026, 8:42.
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Passat 3C or Superb 3T emergency unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts S3 or S4 seats in an Audi 80 or other sports seats? Transmission, Chassis, Body & Interior
No new posts Immobilizer system, version 2 or 3 / with or without CAN ... On-Board Diagnostics (OBD)
No new posts WBK vs. TDI: Which is Best? Diesel Engine Technology
No new posts Oil VW 505.01 or 507.00 Upload
