ASZ Pressure Hoses for Intercooler
captaindickei
Karma: +1 / -1   Thank you, like it!
Post22-02-2011, 17:34    Subject: ASZ Pressure Hoses for Intercooler Quote
Hey,
"On a Golf IV with an ASZ engine, the intercooler was leaking, and we have a new one here (quite a bit of oil came out)."
The problem is:
I just checked and cleaned the two pressure hoses. I have a feeling they are nearing the end of their lifespan and probably aren't completely airtight anymore. It's also difficult to test with a compressor.
At "Freundlicher," the two pressure hoses together cost approximately 75 euros. That's simply too expensive for just two small pieces of hose.
Have you had any experience with these pressure hoses? Do these typically leak, or is it enough to just replace the four seals?
I have attached an image of the two parts.
Best regards and thank you.
 Druckschläuche und Kupplungen, Ladeluftsystem ASZ Motor.
 File size:  1.72 MB
 Viewed:  2277 times
Post22-02-2011, 17:47    Subject: ASZ Pressure Hoses for Intercooler Quote
Ah, that lovely, permanently leaky connector system. That's already garbage, even when it's new. icon_twisted.gif
Replace the seals and just accept that it will always be slightly leaky.
Alternative: Attach.
captaindickei
Post22-02-2011, 17:48    Subject: ASZ Pressure Hoses for Intercooler Quote
Thank you for the reply; (or Thank you for your answer;).
I haven't seen a single TDI yet where everything is completely dry...
Then I can leave the seals in place and reassemble it like that, right?
Post22-02-2011, 17:51    Subject: ASZ Pressure Hoses for Intercooler Quote
captaindickei wrote:
then I can leave the seals in place and reassemble it like that, right?
It should definitely be a little better. It doesn't cost the world, and I would go along with it if it's already falling apart. icon_wink.gif
captaindickei
Post22-02-2011, 18:49    Subject: ASZ Pressure Hoses for Intercooler Quote
Okay, let's see where I can quickly get those tomorrow.
Normally, a little bit of boost pressure should always escape, right?
Post22-02-2011, 19:52    Subject: ASZ Pressure Hoses for Intercooler Quote
Normally, shouldn't there always be a little bit of boost pressure escaping there?
Minimal, yes.
captaindickei
Post22-02-2011, 19:53    Subject: ASZ Pressure Hoses for Intercooler Quote
Is there maybe some kind of filler or something to make it seal?
He's constantly messing with me.
Post22-02-2011, 19:57    Subject: ASZ Pressure Hoses for Intercooler Quote
Maybe there's some kind of sealant or something like that to make it airtight...
Forget about sealant; the minimal movement between the two parts will immediately make it leak again.
If it really sticks together and becomes impossible to separate.
captaindickei
Post22-02-2011, 19:58    Subject: ASZ Pressure Hoses for Intercooler Quote
Hmm, using glue is also a bit unprofessional...
Then I'll have to buy 4 seals from VW, even though they cost over 3 euros each.
Post22-02-2011, 20:03    Subject: ASZ Pressure Hoses for Intercooler Quote
hmm, gluing things is also a bit unprofessional...
No new posts Intercooler for Audi TT/A8 TDI 150 Diesel Engine Technology
No new posts RS4 Intercooler for A4 TDI Diesel Engine Technology
This topic is locked, you cannot edit or reply. Oil in the air cooler Diesel Engine Technology
No new posts Water Cooling for Intercoolers Diesel Engine Technology
