Error code P2178 - Engine running too lean (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Karma: +793 / -0   Thank you, like it!
Post06-03-2021, 12:42    Subject: Error code P2178 - Engine running too lean Quote
The error code P2178, "System too lean at idle," is detected by measuring the lambda sensor or the mass airflow sensor.
Identical Error Codes: P2178 / 008568
Possible Causes:
- Excessive fuel supply (leaks at the fuel injector valve)
- Clogged air intake to the engine (air filter)
- Incorrect fuel pressure sensor (G247) installed
- Defect in the mass airflow sensor or its wiring (check the values for plausibility)
The error code P2178 refers to cylinder bank 1 of the engine, and error code P2180 indicates the same issue for cylinder bank 2.
Ratings - Error code P2178 - Engine running too lean
No new posts Error code P2177 - Lean condition system during idle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P2187 - Bank 1, System Too Lean (Idle) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Keyless Entry Installation Guide by IN.PRO Troubleshooting & Guides
No new posts Fehlercode 65535,Leerlauf ztw. nach dem Starten zu hoch On-Board Diagnostics (OBD)
No new posts Fabia 1,2 BMD Mixture too fatty Gasoline Engine Technology
No new posts Signal too slow, signal too fat 3.0 TDI CTBA Diesel Engine Technology
No new posts TDI Tuningmaßnamen im System Diesel Engine Technology
