Audi A4 Climate Control: Pixel Errors & Compatible Parts
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Gremlin
Avatar-Gremlin
Karma: +91 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Post29-03-2011, 18:04    Subject: Audi A4 Climate Control: Pixel Errors & Compatible Parts Quote
As the title says: I have a climate control panel for an Audi A4, year 1997, available - it's defective (readable and functional, but with unsightly display errors).
According to the label, part number is 8D0820043H.
Unfortunately, I can't find the exact same type used, but something similar, for example.
8D0820043F
or even visually identical parts like 8L0820043D, which are actually intended for the Audi A3 8L (pre-facelift).
Does anyone know the exact differences or other uses?
Thank you.
Translated on 03-08-2026, 4:02.
Post29-03-2011, 18:23    Subject: Audi A4 Climate Control Panel: Pixel Errors & Compatible Types Quote
I can't directly help you right now, but I still have a control panel. If you want, I can check the number for you. icon_wink.gif
Translated on 03-08-2026, 4:04.
Gremlin
Avatar-Gremlin
Post29-03-2011, 18:53    Subject: Audi A4 Climate Control: Pixel Errors & Compatible Parts Quote
Thank you, Michael; it's not necessary. But thank you anyway. icon_biggrin.gif
"I happen to have the part number -8D0820043F- on hand, and it's cheap. I'll take a look, and if it doesn't work, I might just replace the display itself; it's connected with a flat ribbon cable."
bloesch
Post30-03-2011, 5:48    Subject: Audi A4 Climate Control: Pixel Errors & Compatible Parts Quote
The control panel with index F was replaced by the control panel H in mid-1996.
The control unit with part number 8L0... was also used in the A4 starting in 1998. However, I'm unfortunately not sure if it will work for you.
Translated on 03-08-2026, 4:05.
voodoo
Post30-03-2011, 9:50    Subject: Audi A4 Climate Control: Pixel Errors & Compatible Parts Quote
If you have a bit of talent when it comes to electronics, you can often repair the display yourself and at a low cost.
The displays are connected via so-called conductive rubbers. Over time, these rubbers lose their plasticizers and no longer conduct electricity properly.
Often, you can tell by the fact that the pixel defects change with temperature and are not static.
You can purchase replacement rubber guides from most major electronics retailers.
Replacing it is a bit fiddly, but doable.
Translated on 03-08-2026, 4:06.
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zuordnung Audi Typ, MKB, GKB, AKB, MJ Technical Data
No new posts AFN Engine Control Unit: Compatible Alternatives On-Board Diagnostics (OBD)
No new posts Klimabedienteil "AUTO" Taste Transmission, Chassis, Body & Interior
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts FIS in the Audi Transmission, Chassis, Body & Interior
