LD Increase Problems? Troubleshooting Guide.
mfg!
Post22-03-2003, 19:31    Subject: LD Increase Problems? Troubleshooting Guide. Quote
Hello.
I recently used VAG COM to read the data from my A4 TDI, and it showed 0.8 BAR (90 horsepower). Now, I've replaced the SMD 10kΩ resistor with a potentiometer, using a 10-cent potentiometer.
Okay, everything is working optimally now, but my LD (likely referring to a pressure or voltage reading) is at 0.6 without pressure and 0.8 bar with pressure, using a potentiometer connected between terminals 2 and 3.
With the other potentiometer (replacing the 10 kOhm one) in the control unit, nothing changes, even when driving without a potentiometer, there's no difference in the LD (likely referring to a sensor reading). Even with a 30 kOhm potentiometer, I still get 0.8 BAR.
What did I do wrong? I also have a 1.5 bar sensor with the suffix 210 installed. It should work, right? I also have a manual LD display, and it shows the same readings as VAG-COM!
Translated on 11-09-2026, 4:20.
diesel.gustav
Post22-03-2003, 21:11    Subject: LD Increase Problems? Troubleshooting Guide. Quote
Deleted upon request.
Translated on 11-09-2026, 4:22.
mfg!
Post23-03-2003, 13:15    Subject: LD Increase Problems? Troubleshooting Guide. Quote
Hello diesel.gustav.
Now, as you probably also noticed, this is not a diesel forum. And I don't want to do any advertising, icon_question.gif why would I?
I need help with my problem, and I urgently need it. A friend told me about your company a while ago. Well, I tried the '10 Cent Tuning' first on a Seat with 110 horsepower, and it worked perfectly (with LD increase).
Okay, so I have an A4 now, but unfortunately, something is wrong with it. I need the car to get to work on Monday, but I can't drive it like this if I don't know what's going on!
Okay, this isn't an advertisement, but a serious problem. If you find it disturbing, I can remove the signature. However, I don't believe these pages have anything to do with diesels of any kind.
Best regards!
Translated on 11-09-2026, 4:23.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Efficiency increase through turbocharger? Diesel Engine Technology
No new posts Diagnosis Problems: What to Do Next On-Board Diagnostics (OBD)
No new posts GRA Installation Issues: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Problems after renovation... Diesel Engine Technology
