DSG 7-Speed: STRONIC Reset Guide
A3-Besitzer
Registered VCDS User
Post03-05-2011, 15:05    Subject: DSG 7-Speed: STRONIC Reset Guide Quote
Unfortunately, the search function didn't return any results.
Is there perhaps already a guide available somewhere that I can use to reset/initialize the 7-speed STRONIC (LQN) transmission using VCDS?
(The Rosstech wiki has instructions for 6-speed transmissions, but not for 7-speed transmissions.)
Thank you very much.
AUDI A3 8PA, MJ2010, 1,6l TDI, 77KW/105PS, 7-Gang-STRONIC, KB: CAYC/LQN
Translated on 16-10-2026, 18:14.
Post03-05-2011, 16:58    Subject: DSG 7-Speed: STRONIC Reset Guide Quote
Please post a complete vehicle scan. Be careful about giving instructions to the DSG control unit.
Translated on 16-10-2026, 18:15.
A3-Besitzer
Post03-05-2011, 18:37    Subject: DSG 7-Speed: STRONIC Reset Guide Quote
Yes, that's why I only want to do it with instructions.
Please provide the text you would like me to translate from German to English. I need the text to be able to translate it.
Thank you for your help.
VCDS Version: RKS 10.6.3
Data as of: 20110306.
Wednesday, March 30, 2011, 18:44:02:36089
Vehicle type: 1K0
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 47 52 56 61 62 72
((Vehicle Identification Number: XXXXX, Mileage: XXXXXX km)) deleted upon request...
01-Motor -- Status: OK 0000
02-Gearbox -- Status: OK 0000
03-Brakes -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate/Heating -- Status: OK 0000
09-Onboard network -- Status: OK 0000
10-Parking assist 2 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-inch steering wheel -- Status: OK 0000
17-in-1 instrument -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-way immobilizer -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
56-Radio -- Status: OK 0000
61-Battery regulation -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die Bäume, und die Blätter rascheln leise. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen."
Address 01: Engine (J623-CAYC) Label file: RKS\03L-906-023-CAY.clb
Part number SW: 03L 906 023 N. Part number HW: 03L 906 023 L.
Part: 1.6L R4 CR td H23 6086
Revision: -------- Serial Number: AUX7Z0J3FNQ0GK
Encoding: 00254036032401080000
Operating number: WSC 06314 000 00000
ASAM Dataset: EV_ECM16TDI02103L906023N 001007
ROD: EV_ECM16TDI02103L906023N.rod
VCID: 3146426AD1AF
No errors found.
Readiness: 1010 0000
Address 02: Transmission Label file: RKS\0AM-300-04x.lbl
Part number SW: 0AM 300 047 E, HW: 0AM 927 769 D.
Part: GSG DSG AG7 403 1814
Revision: 00040034 Serial number: 00001004100355
Encoding: 0000020
VCID: 3146426AD1AF
No errors found.
Address 03: Brakes (J104)
Label file: RKS\1K0-907-379-60EC1F.clb
Part number SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Encoding: 1142201209280002881104EC901F0051390800
VCID: 7AD4A5464C59
No errors found.
Address 08: Climate Control/Heating
Label file: RKS\8P0-820-043.lbl
Part number SW: 8P0 820 043 BN
Part number HW: 8P0 820 043 BN
Component: Climate Control Unit H09 0150.
Revision: 000577 Serial Number: 8P0820043BN
Operating Number: WSC 00000 000 00000
VCID: 79D6BA4A495F
No errors found.
Address 09: Body Control (J519)
Label file: RKS\8P0-907-063.clb
Part number SW: 8P0 907 063 A, Hardware: 8P0 907 063 A.
Part: BCM PQ35 M 105 0575
Revision: 00105 AK
Encoding: 46000A2FB0051AC0207040E02000015C431A29AA014DC12AE4008F800041
VCID: 32444D66D4A9
Part number SW: 8P1 955 119 F. Hardware number: 8P1 955 119 F.
Part: Wiper AU350 H10 0040.
Encoding: 00DD13
No errors found.
Address 10: Parking Assist 2 (J446) Label file: RKS\8P0-919-475-7X1.clb
Part number SW: 8P0 919 475 G, HW: 8P0 919 475
Component: PARKHILFE 4K H06 0120.
Revision: 11001001 Serial number: 93641011714576
Encoding: 000103
VCID: 42A41DA66409
No errors found.
Address 15: Airbag (J234)
Label file: RKS\8P0-959-655-10.clb
Part number SW: 8P0 959 655 P, Hardware: 8P0 959 655 P.
Component: Airbag AU1042 H07 0200
Revision: -------- Serial Number: 003FB006X2VF
Encoding: 30314238303830303035554A304C38503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 4F822492A75B
Crash sensor for driver-side side airbag:
Serial number: 3572DRB40000B31CD8D4
Crash sensor for side airbag, passenger side.
Serial number: 3582DRB40000B364F0F+
Crash sensor for rear side airbag, driver's side.
Serial number: 35128RB4000056DD2CB.
Crash sensor for rear side airbag, passenger side.
Serial number: 35228RB4000056DD518R
Crash sensor for front airbag, driver's side:
Serial number: 35547RB4000058BBF74+
Crash sensor for front airbag, passenger side.
Serial number: 35647RB4000058B97D3.
No errors found.
Address 16: Steering wheel
Label file: RKS\8P0-953-549.lbl
Part number SW: 8P0 953 549 K, Part number HW: 8P0 953 549 K.
Component: J0527 H37 0070
Encoding: 0012142
VCID: 46AC01B64821
Part number: XXXXXXXXXXX
Component: E0221 H06 0030
No errors found.
Address 17: Combination Instrument
Label file: 8P0-920-xxx-17-MY8.clb
Part number SW: 8P0 920 932 C, Hardware: 8P0 920 932 C.
Bauteil: KOMBIINSTR. VDO H03 0990
Revision: D0H03005 Serial Number: 2243J005072801
Coding: 0000028
Operating number: WSC 35122 142 65962
VCID: 34484B7E2EBD
No errors found.
Address 19: CAN Gateway
Label file: RKS\1K0-907-530.lbl
Part number SW: 1K0 907 530 AF, HW: 1K0 907 951.
Component: J533, Gateway, H17 0233.
Revision: H17 Serial Number: 1521J1042903B0
Encoding: EDA07F06100202042102
VCID: 6BFA90023303
No errors found.
Address 25: Immobilizer
Label file: RKS\1K0-920-xxx-25.lbl
Revision: D0H03005 Serial number: AUX7Z0J3FNQ0GK
VCID: 34484B7E2EBD
No errors found.
Address 42: Door electric, driver
Label file: 8P0-959-801-MIN3.lbl
Part number SW: 8P0 959 801 N, Hardware: 8P0 959 801 N.
Component: Door Seal H04 0100
Encoding: 0131324
VCID: 46AC01B64821
No errors found.
Address 44: Steering Assist
Label file: RKS\1Kx-909-14x.lbl
Part number: 1K0 909 144 J
Component: EPS_ZFLS, Class 232, Part Number 3001.
Revision: 00H17000
Operating number: WSC 02069 000 90108
VCID: 3146426AD1AF
No errors found.
Address 47: Soundsystem Label file: RKS\8Px-035-382.lbl
Part number SW: 8P4 035 382 E, Part number HW: 8P4 035 382 E.
Component: AB2 SUBWOOFER BOX H07 0180
Revision: 00006 Serial number: 92158068082894
VCID: 364C717638C1
No errors found.
Address 52: Door electric, passenger side.
Label file: RKS\1K0-959-702-MIN3.lbl
Part number SW: 8P0 959 802 N HW: 8P0 959 802 N
Encoding: 0131324
VCID: 47B20CB24F2B
No errors found.
Address 56: Radio
Label file: RKS\8J0-035-1xx-56.clb
Part number SW: 8P0 035 186 S, Hardware number: 8P0 035 186 S.
Component: R Concert2+ H03 0280
Revision: 00H03000 Serial Number: AUZ1Z3K6038412
Encoding: 0330011
VCID: 42A41DA66409
No errors found.
Address 61: Battery Management (J840)
Label file: RKS\1K0-907-534.clb
Part number SW: 1K0 907 534, HW: 1K0 907 951.
Component: Battery management system H17 0233.
Revision: -------- Serial Number: 1521J1042903B0
Encoding: 0303085A
VCID: E8F06F0EA2F5
Part number SW: 1K0 915 181 E, HW: 1K0 915 181 A.
Component: J367-BDM H07 0140
No errors found.
Address 62: Door electric, left/right.
Label file: RKS\8P4-959-801.lbl
Part number SW: 8P4 959 801 F. Hardware: 8P4 959 801 F.
Component: Door Module H04 0050
Encoding: 0131288
Operating number: WSC 06314 000 1012544
VCID: 42A41DA66409
No errors found.
Address 72: Door electric, high, right.
Label file: RKS\8P4-959-802.lbl
Part number SW: 8P4 959 802 F HW: 8P4 959 802 F
Component: Door module H04 0050
Encoding: 0131288
VCID: 43AA18A27B13
No errors found.
End.
Translated on 16-10-2026, 18:41.
No new posts CNG service reset, gas tank Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A1, A4, Q3, A5, A6, Q5, A7, Q7, A8 (Digital Radio Re... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts HEX-NET Reset to factory settings On-Board Diagnostics (OBD)
No new posts 5-Speed Gearbox: Sharan/Alhambra/Galaxy (AFN) Change? Diesel Engine Technology
No new posts Golf 5 1.9 TDI 5-speed 6-speed gearbox ZMS clutch Diesel Engine Technology
No new posts Reset Engine Control Unit (ECU) - How To Diesel Engine Technology
