Audi A4 Wiring Diagram: MSA 15.5 Controller
turboandy
Post13-04-2011, 9:34    Subject: Audi A4 Wiring Diagram: MSA 15.5 Controller Quote
Hi everyone, does anyone happen to have a wiring diagram for an Audi A4 from the years 1996-1997?
I have a control unit, model 8.97, but it has an 80-pin connector, which I can't use because I have a 68-pin connector.
I would be grateful for any answers.
Hat Audi die gleiche Pin Belegung wie VW. zB. Passat.
It's about converting a 1-liter or AFN engine to a Caddy 14d. The engine control unit (ECU) will be from an Audi A4 automatic transmission.
Do you need to change any settings on the control unit via the diagnostic connector to switch from automatic to manual transmission?
The clutch pedal signal, pin 68/17, needs to be retrofitted to the wiring harness.
Translated on 22-10-2026, 21:55.
Back to top Profile PM Email
Wiesel
Post13-04-2011, 11:28    Subject: Audi A4 Wiring Diagram: MSA 15.5 Controller Quote
You should recode the MSA15 to switch mode (-> diagnosis) if that is possible.
(If you provide the part number, I might be able to tell you.)
The wiring for the clutch and the second brake pedal input is different in Audi vehicles compared to Volkswagen vehicles. This is either due to a difference in the vehicle's wiring harness.
Modify it accordingly or use a different control unit.
Micha
Translated on 22-10-2026, 21:56.
turboandy
Post13-04-2011, 12:11    Subject: Audi A4 Wiring Diagram: MSA 15.5 Controller Quote
Thank you for the response.
Bosch part number 0 281 001 425/426.
Audi, number 028 906 021 CE.
Control unit manufactured in May 1996.
Yes, I believe you can switch it using the diagnostic connection, but I read about it in the T3 bus forum, but I can't find the text anymore.
I've also heard that the clutch and brake signals are different.
However, I doubt that's the case, which is why I'm looking for the circuit diagram.
Someone told me that the pinout was the same until the newer 80-pin model was replaced.
44 (receives 12V from the brake system) is the brake light, and 20 (is interrupted when braking) is the brake light control signal (4-pin brake light switch).
17. When coupling, it is interrupted by a normally closed switch (ventilation valve).
Just like with my Golf 3, I need it in writing; I've already invested a lot of money in this control unit. The immobilizer has been deactivated, and the engine has been tuned to 140 horsepower.
Translated on 22-10-2026, 21:58.
Wiesel
Post13-04-2011, 13:56    Subject: Audi A4 Wiring Diagram: MSA 15.5 Controller Quote
turboandy wrote:
...I have already invested a lot of money in this control unit. Immobilizer deactivated and tuning to 140 horsepower
If the person who made it can't tell you how the pins are arranged, then...
How to convert an automatic transmission to a manual transmission (yes, it's possible with the 021CE), you should seriously consider...
Think about what you're actually investing in...
Micha
Translated on 22-10-2026, 22:00.
turboandy
Post14-04-2011, 17:25    Subject: Audi A4 Wiring Diagram: MSA 15.5 Controller Quote
I now have the wiring diagrams for the 1.Z and AFN engines, manufactured between 1995 and 1996.
Sure, here is the translation of the text from German to English, in PDF format:
[PDF]
**Translation:**
In PDF format.
I've also managed to get another automatic transmission with the AFN I bought.
Got the number 028 906 021 CK.
Can this also be switched via diagnostics?
The wiring harness is perfect. Unfortunately, the cable for pin 17 of the clutch pedal switch is missing.
Translated on 22-10-2026, 22:02.
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts AAT ECU Wiring Diagram & Bosch Part Number Help On-Board Diagnostics (OBD)
No new posts Audi 80 B4 Schaltplan (Pinbelegung) Diesel Engine Technology
No new posts Audi 100 V6 Wiring Diagram - 10/91 Diesel Engine Technology
No new posts Audi A5 Headlight Wiring Diagram Transmission, Chassis, Body & Interior
