TDI Starter Compatibility: Find the Right One
Boro
Post29-03-2011, 8:30    Subject: TDI Starter Compatibility: Find the Right One Quote
'On my Ibiza 6k, manufactured in 2001, the starter motor (MBK ASV) is failing, so I would like to replace it. The currently installed starter motor should be a 02A 911 024 D, 12V 2kW.'
Does anyone know if a starter motor from a newer generation of TDI vehicles, such as a Golf 5, would be compatible?
'With my old Ibiza from 1998 with the AFN engine, I was able to easily use a starter motor from a Bora made in 2002. The Ibiza had the part number 023, and the Bora also had the 024 part number.'
Ideally, I would prefer a used starter motor with low mileage and from a more recent production year, as these are also generally more affordable.
Translated on 21-10-2026, 16:53.
No new posts Starter Motor Noise: VW Golf 4 & Similar Troubleshooting & Guides
No new posts Bosch MAF Sensors: Compatibility Guide Diesel Engine Technology
No new posts Auxiliary Heater Audi Q7 Compatibility Diesel Engine Technology
No new posts Haldex Clutch Part Numbers & Compatibility Transmission, Chassis, Body & Interior
No new posts Passat 1.9 TDI (AVF), Compatibility of Pump Nozzle Injectors Diesel Engine Technology
