21-03-2003, 14:50 Subject: Daniel Düsentuning: 30% More Power? |
Hello.
Mozz pointed this out in another thread.
http://www.kw-systems.de/duesedia.htm
The whole thing seems a bit strange to me, even if we assume that the 62 or 81 kW, according to the diagram, represents the power at the wheel (with remarkably low losses between the motor and the roller).
Wenn z.B. durch eine Vergrößerung des Einspritzquerschnitts bis zu 30% mehr Leistung zwischen 2700 und 4000 rpm erreicht werden, dann paßt IMO nicht dazu, dass die Leistung darunter haargenau den Normaldüsen entspricht (Drehzahlen anhand der Geschwindigkeiten und üblichen Übersetzungen im 4. Gang estimated).
Incidentally, the measured motor output is quite low in the range of the typical peak torque, around 1900 rpm or 66 km/h: according to the diagram, 24 kW corresponds to approximately 27 kW of motor power, which would result in a torque of around 136 Nm, a deficit of about 1/3 of the AHU's nominal value of 202 Nm.
If a TDI engine doesn't really start to perform until around 2700 rpm, it reminds me of full-throttle acceleration in first gear, where the engine revs up faster than the turbocharger can keep up. Consequently, the dynamometer flywheel used for the 4th gear test seems somewhat unrealistic, and/or the turbocharging system may have had a problem during the measurement, which both leave a rather questionable impression.
Furthermore, the measurements were supposedly taken without electronic tuning, meaning the pump's flow rate remained constant.
However, approximately 30% more diesel fuel would need to be delivered to the combustion chambers in order to generate the additional power.
But where does this significant excess come from? Or, where does it disappear to when the original nozzles are installed?
Or should the tuning nozzles instead increase the engine's efficiency by 30% (if so, how??) - and do this selectively in the higher RPM range, where diesel engines typically experience a rapid drop in efficiency?
Looking at the power delivery above 4000 rpm, the "power curves" actually give the impression of a complete technical revolution: just before the measurement stops, the tuned nozzles provide almost double the standard power – and this, supposedly, with the same pump flow rate!
Or should the increased performance come from the addition of several effects, meaning "a little" more efficiency, "a little" more diesel in the combustion chamber, slightly altered measurement conditions, a slightly adjusted pump, etc.  ?
What do you think about it?
Is there perhaps a test pilot here with a 66 kW engine who needs new nozzles anyway, and who would be willing to run a few DZR cycles with the old and the tuned nozzles, and then "swear" in the forum to provide accurate information?
He may be brave, but his "rocket car" might not pass the emissions test... Gruß Ulf
Translated on 22-10-2026, 23:32.
Profile PM Garage |
diesel.gustav Guest
22-03-2003, 19:44 Subject: Daniel Düsentuning: 30% More Power? |
Deleted upon request.
Translated on 22-10-2026, 23:36.
22-03-2003, 22:41 Subject: Daniel Düsentuning: 30% More Power? |
diesel.gustav wrote: |
Fuel injectors with slightly modified (enlarged) spray holes result in a higher fuel injection volume. This is especially noticeable in the higher RPM range, because that's where the pump is most likely to have difficulty getting the fuel through the spray holes. |
Hello Gustav.
...because the high flow rate before the "narrowing nozzle" also generates the highest pressure, which is quite clear.
But if not all of the juice is flowing through the nozzle, where does it go?
"In PD engines, as far as I know, pre-detonation is actually caused by compression effects. This means that some of the fuel-air mixture remains in the system, from the pump to the injector, which would normally be expelled."
Should this also be a factor with the VP 37?
Or perhaps it's due to elastic bulges in the fuel injection lines?
Or are there increased leakage losses in the pump?
But can all of this really make such a difference that the normal nozzles in the upper RPM range restrict about 30%  of the flow rate  ? Gruß Ulf
Translated on 22-10-2026, 23:37.
Profile PM Garage |
kenny Guest
23-03-2003, 1:25 Subject: Daniel Düsentuning: 30% More Power? |
Isn't the excess fuel returned to the tank? The fuel injection pump surely pumps out much more than is actually burned. In reality, I estimate that about 3-6 liters are burned per hour (I'm just roughly estimating because I drive about 5 liters per 100km, and it takes me about an hour to drive 100km...).
Okay, let's convert that to the number of injection events per hour, and you'll also get the amount of fuel injected per ignition in microliters. Doesn't the pump have a much higher flow rate?
Translated on 22-10-2026, 23:39.
23-03-2003, 9:20 Subject: Daniel Düsentuning: 30% More Power? |
kenny wrote: | Isn't the excess fuel returned to the tank? The fuel injection pump surely pumps out much more than is actually burned. In reality, approximately 3-6 liters are burned per hour on average (I'm just roughly estimating because I drive about 5 liters per 100km, and it takes me about an hour to drive 100km...).
Calculate that and convert it to the number of injection events per hour, and you'll also get microliters injected per ignition. Doesn't the pump have a much higher flow rate? |
Hi Kenny,
The amount of material extracted under low pressure is actually much larger than the amount consumed.
This concerns losses specifically in the high-pressure area between the distributor piston and the nozzle, and from there, only a small amount of leakage, a few percent (?), flows back into the tank. Gruß Ulf
Translated on 22-10-2026, 23:41.
Profile PM Garage |
diesel.gustav Guest
23-03-2003, 12:02 Subject: Daniel Düsentuning: 30% More Power? |
Translated on 22-10-2026, 23:42.
Michael II Profi-Schrauber
Joined: 04/12/2002 Posts: 1132 Karma: +3 / -0 Location: Stuttgart
23-03-2003, 16:27 Subject: Daniel Düsentuning: 30% More Power? |
Hello Ulf,
In common rail diesel engines, the fuel is also significantly heated due to the routing of the fuel lines. The fuel is pumped through the tandem pump (directly mounted to the injection pump) and then flows through bores in the injection pump to the individual common rail injectors and back. This alone causes the fuel to become considerably warmer. Tschüss
Michael II
23-03-2003, 17:08 Subject: Daniel Düsentuning: 30% More Power? |
diesel.gustav wrote: | A well-tuned, up-to-date EDC system for a TDI engine with a VP37 achieves peak pressures of approximately 1200 bar at the injector. Diesel is already highly compressible, so measures were taken on the VP37 to reduce the dead volume and thus compensate for this undesirable property.
The bloating is understandable because the pump delivers fuel at high speeds roughly twice as fast as the (standard) injectors can inject it.
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
Leakage losses also increase with higher pressure.
The standard-tuned EDC system "doesn't hold back 30%", but rather corresponds to the desired configuration.
Please provide the text you would like me to translate from German to English.
If someone installs nozzles with different or larger spray patterns, they will disrupt the system's calibration. If they are only focused on increasing power and don't care about anything else, they can increase the fuel injection volume by using larger spray patterns.
Möglicherweise verliert er dadurch die Betriebserlaubnis. But with that...
I'm not very familiar with it. |
Hello Gustav.
Wow, I never would have imagined that things could be this extensive.
But I think your answers will surprise not only me... Thank you for this piece of basic educational material  .
Regarding the operating license: Since even the slightest "noticeable" modification can invalidate the operating license, and as far as I know, the injectors have a significant impact on exhaust emissions, it's likely that the operating license will be voided in this case as well.
 And according to the rule of thumb "Everything that's really fun in a car is illegal," that's a given  . Gruß Ulf
Translated on 22-10-2026, 23:44.
Profile PM Garage |
tim27 Guest
23-03-2003, 18:09 Subject: Larger Nozzles Installed: Benefits & How-To |
Today, I installed the injectors from a Volvo 2.5 TDI 103KW engine into my car for testing. However, I was only able to replace three injectors because I couldn't disconnect the connector for the injector control valve (from the Volvo).
So, just 3 larger nozzles.
After letting it warm up, I gave it some gas for the first time, and sure enough, there was a noticeable increase in power. I immediately did a full acceleration test.
2000-4000 RPM. Previously, with the standard nozzles, the time was approximately 6.6 seconds. With the three larger nozzles, the times were 6.17 seconds and 6.244 seconds.
I suspect that if all four injectors had been replaced, the engine would have become even faster, because in this case, only 'three' cylinders were delivering the power.
However, the engine was like an old steam locomotive. But with a slightly higher boost pressure, that could probably be overcome.
I was still able to witness the initial tests with the larger nozzles, which was fortunate.
Translated on 22-10-2026, 23:48.
Bertil Profi-Schrauber
23-03-2003, 18:30 Subject: Daniel Düsentuning: 30% More Power? |
ulf wrote: | Wow, I wouldn't have believed that all of this could be so extensive.
Hi Ulf,
I thought you would already be familiar with these factors.
While searching for a suitable ESP for my 1Z engine, I came across a pump from ALE. Well, the 1Z and ALE engines are essentially the same. However, when I inquired about the differences between the ALE and 1Z, I was quite surprised:
1. The ALE model has EURO3 emissions standards, while the 1Z model only has EURO2 (more on this later).
2. The ALE has 210 Nm of torque, while the 1Z only has 202 Nm.
3. The ALE has a different ESP (Electronic Stability Program) and different nozzles.
However, the most important thing is that the ALE system has different lines from the pump to the nozzle.
Why? It's quite simple: the ALE has a higher injection pressure than the 1Z. It's only a slight difference, but it's enough that the lines had to be reinforced. That's how you can recognize the dynamics of the system.
This change explains the improved emission performance and higher torque of the ALE motors. Gruß Bertil
Translated on 22-10-2026, 23:51.
23-03-2003, 21:58 Subject: Daniel Düsentuning: 30% More Power? |
Bertil wrote: | | I thought you would already be familiar with these factors. |
Hi Bertil.
Basically, yes, but I've always considered it to be insignificant and without any real-world impact, so I've kind of "dismissed" it.
However, if an increase in performance of around 30% seems only achievable through larger nozzle diameters, then that's quite a significant amount – and that was something new to me. Gruß Ulf
Translated on 22-10-2026, 23:53.
Profile PM Garage |
tim27 Guest
23-03-2003, 22:34 Subject: SEO-Optimized Title Translation:
**"Best SEO Tools: A Comprehensive Guide"** |
Okay, let me try to explain how it's possible to achieve more power 'just by using nozzles.'
Sure, please provide the text you would like me to translate from German to English.
-serien injectors (5-hole injector) require a certain amount of fuel, let's say x, for 1 second.
- The amount of fuel 'y' that is lost due to leakage around the high-pressure piston in the pump (during pressure build-up) is.
With larger nozzles (7-hole nozzle), where the individual injection holes are smaller than those in a 5-hole nozzle, the nozzle opening pressure can be slightly reduced (while the quality of fuel distribution does not decrease due to the smaller injection holes).
Due to the slightly lower opening pressure, the injection pressure is also slightly lower, which results in reduced leakage losses at the high-pressure piston, allowing for more fuel to be injected.
I think I've explained it reasonably well, or at least I've tried to.
What I can't believe is that it can produce more than 20% more power.
Translated on 22-10-2026, 23:54.
24-03-2003, 6:57 Subject: Daniel Düsentuning: 30% More Power? |
ulf wrote: | ...
Basically, yes, but I've always considered it to be insignificant and without any real-world impact, so I've kind of dismissed it.
Hi Ulf,
For something as cheap as peanuts, I wouldn't expect it to hold up at 1200 bar.
It is precisely these "peanuts" that cause such problems for the CR system in achieving the high injection pressures.
Tim27 wrote: | | What I can't believe is that it can produce more than 20% more power | .
... neither do I.  Gruß Bertil
Translated on 22-10-2026, 23:57.
mozz
24-03-2003, 11:07 Subject: Daniel Düsentuning: 30% More Power? |
Hello!!
I finally installed the KW injectors in a 1Z engine! My conclusion:
"It offers a noticeable performance boost, but only with the standard software. The Passat has over 250,000 kilometers on the odometer, so we thought it wouldn't hurt to replace the injectors, and we decided to use the ones from KW."
"During the first test with the original software, I was very impressed because there was a noticeable increase in performance. However, it's different with the modified software; you only notice the performance gain at lower RPMs. At higher RPMs, it just seems to struggle and doesn't actually perform any better."
I put it in gear and saw that it was running at 190 km/h with only half the accelerator pedal pressed. When I pushed it harder, all I got was black smoke coming out of the exhaust, but it wasn't getting any faster! I think the fuel injection is already delivering too much fuel, and it's reached the point where combustion is no longer efficient.
Am I correct in my assumption?
Sure, here's the translation:
"gruzz mozz" translates to "greetings" or "hello" in English.
Translated on 22-10-2026, 23:59.
tim27 Guest
24-03-2003, 12:32 Subject: SEO: Best Practices for Website Optimization |
Did you perform a flow test after installing the K-series injectors, specifically in the range of 2000-4000 RPM?
What about the turbo boost? Did you have the standard setting, or have you increased it? And if so, how much... in bar?
I'm curious to see what the results of the permeability test will be.
See you later.
Translated on 23-10-2026, 0:00.
mozz
24-03-2003, 14:30 Subject: Daniel Düsentuning: 30% More Power? |
Hello!
I can only run the pressure test again on Friday - and I will! So, I'll be printing a test series in the standard configuration (as expected) with the chip set to 1.25 bar.
I will report back as soon as I have completed the test!!
Translated on 23-10-2026, 0:01.
