Log assessment for BKD 2.0 TDI
servusssss
Post11-02-2011, 13:12    Subject: Log assessment for BKD 2.0 TDI Quote
Hello everyone,
"On my Golf 5 BKD 2.0 TDI 140hp with 65370 km, I have the following error:"
Code:
Adresse 01: Motor        Labeldatei: RKS\03G-906-016-BKD.lbl
   Teilenummer SW: 03G 906 016 AQ    HW: 028 101 184 8
   Bauteil: R4 2,0L EDC G000SG  7000
   Revision: 12345678    Seriennummer: VWZ7Z0E2487915
   Codierung: 0000172
   Betriebsnr.: WSC 01279 785 00200
   VCID: 72E053081429
1 Fehler gefunden:
16618 - Ladedruckregelung: Regelgrenze überschritten
            P0234 - 000 -  -
             Umgebungsbedingungen:
                    Drehzahl: 2226 /min
                    Drehmoment: 216.0 Nm
                    Geschwindigkeit: 74.0 km/h
                    Last: 46.3 %
                    Spannung: 14.44 V
                    Binärwert: 00101000
                    Druck: 1876.8 mbar
                    Druck: 2254.2 mbar
Readiness: 0 0 0 0 0
I just checked the VTG. When I moved it with a syringe, it didn't stick and moved easily. I also checked the vacuum hoses and didn't find anything wrong.
When I run the actuator test using VAG-Com, the VTG moves in the same way as it does when using a syringe. I did that both when it was cold and when it was hot.
I also created logs for MWB 03, 08, and 11, and they show some overshoots. The boost pressure is always approximately 200 mbar above the target value.
Now, my question is, is this normal for this engine?
If not, is the turbo blown, or what's your advice?
"Thank you very much!"
Sure, here's the translation:
"PS:"
Link to the log files: /viewtopic.php?p=182736#182736
Post11-02-2011, 13:38    Subject: Log assessment for BKD 2.0 TDI Quote
It looks like the VTG isn't opening wide enough.
The N75 filter releases a lot of pressure (low percentage), but it still restricts the flow too much.
Can you extend the rod further out than its own length?
EDIT
Is the box chipped, or what?
- Revision 12345678
- The maximum torque of 362 Nm seems a bit high (my BMR releases 370).
servusssss
Post11-02-2011, 14:46    Subject: Log assessment for BKD 2.0 TDI Quote
I've just checked the VTG again. I can't move the support rods any further; they're already at their maximum limit. You can also hear the mechanical sound. Connection to the VTG/vacuum sensor.
No, the car's ECU (engine control unit) is not chipped. The car was purchased new and nothing has ever been modified (no chip or tuning box).
Otherwise, everything else is original.
SG
Karma: +784 / -0   Thank you, like it!
Post11-02-2011, 17:33    Subject: Log assessment for BKD 2.0 TDI Quote
You could try unscrewing the vacuum cylinder from the loader; then you'll be able to see if the VTG (variable geometry turbocharger) is operating smoothly. The adjustment lever must automatically drop down; the weight of the can alone is many times greater than the force required to operate it. icon_idea.gif
The distance along the path near the adjustment lever with the attached container is approximately 1 cm.
dieselmartin wrote:
(my BMR indicates 370)
Expected: Maximum torque of approximately 390 Nm, limited by the transmission torque.
"LG" translates to "Best regards" or "Sincerely" in English.
servusssss
Post14-02-2011, 11:37    Subject: Log assessment for BKD 2.0 TDI Quote
Today, I tried to see if I could unscrew the vacuum diaphragm. Unfortunately, I couldn't, because one of the screws holding the vacuum diaphragm in place is located behind the adjustment lever. It never comes out in its built-in state.
The travel distance of the adjustment lever is approximately 1 cm. This occurs when the VTG (presumably a valve or device) is activated, and I draw about 50 ml with the syringe.
The VTG behaves in the same way when I control it using VAG-Com.
Does anyone have any other suggestions for how I can narrow down or identify the error?
If it's the turbo, has anyone ever removed one of these before?
What exactly do I need to take out of there? Is the turbocharger removed from the bottom or the top?
I am grateful for any advice.
SG
Post14-02-2011, 11:50    Subject: Log assessment for BKD 2.0 TDI Quote
I've already experienced "sticky" vacuum cups, meaning that when the vacuum hose is disconnected, they only slowly return to their original position. This could also be a starting point.
I think that if you're not getting the desired results and you've already checked the usual things, then there's no way around upgrading the charger.
servusssss
dieselschrauber likes this.
Post14-04-2011, 10:00    Subject: Log assessment for BKD 2.0 TDI Quote
Hello everyone,
Here's the solution to the problem, late but finally.
I had the following error:
"16618 - Charge pressure control: Limit exceeded."
Now, this error is a consequence of another error.
As is well known, these engines sometimes have a defect in the cylinder head. This was also the case here. The burning of coolant caused the variable geometry turbocharger (VTG) in the turbo to seize, although not always. Therefore, that was the error.
Result: new cylinder head, new turbocharger.
SG
P.S.: To be sure whether you have a cylinder head from the problem series, there is a three-digit number on the head. This number is located on the back, on the driver's side, near the AGR cooler. If this number is less than 125, then it's one from the "trouble" series.
Post14-04-2011, 10:30    Subject: Log assessment for BKD 2.0 TDI Quote
Thank you for the feedback!
No new posts Audi A4, A5, A6, A7, Q5, Q7 3.0 TDI, Oil in the vacuum sy... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI BKD/AZV from 2004, Whistling/Squealing noise unde... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts What is the synchronization angle in a TDI engine? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Log for Assessment at BKD 2.0TDI Upload
No new posts Assessment of rocker arm/camshaft in a T5 Diesel Engine Technology
No new posts lautes Zischen beim Beschleunigen / 2.0TDI Diesel Engine Technology
No new posts Airflow noise and whistling at the 2.0TDI CR CBBB Diesel Engine Technology
