Boost Control: How to Optimize Turbo Pressure
kenny
Post27-03-2003, 13:15    Subject: Boost Control: How to Optimize Turbo Pressure Quote
I have a question about the boost pressure control system. Does it work based on characteristic curves, meaning does the engine control unit (ECU) 'know' about the performance of the turbocharger and then set a boost pressure based on a characteristic curve (e.g., by controlling a valve for a specific time to position the variable turbine geometry (VTG) in a certain way)? Or is the boost pressure actually measured, and then regulated to the target value?
Translated on 20-09-2026, 7:44.
zzzZZ
Post27-03-2003, 13:22    Subject: Boost Control: How to Optimize Turbo Pressure Quote
As far as I know, it's a mixture of both.
At higher engine speeds, the variable turbine geometry (VTG) is already adjusted to a position that is intended to prevent excessively high turbocharger speeds in the event of sudden full acceleration, because the control system is relatively slow to respond.
Starting from this point, the desired boost pressure is regulated by comparing the target value with the actual value.
Translated on 20-09-2026, 7:45.
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty Load Pressure Control Engine Identifier BRE Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger Boost Control Problem - Golf4 AXR Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Loading Pressure Control TDI 1.9l Diesel Engine Technology
No new posts Turbo Control Golf 5 BKC On-Board Diagnostics (OBD)
No new posts Turbocharger Problems: Troubleshooting & Repair Upload
No new posts AFN Turbocharger: Improve Boost Control Upload
