Wolf-Dietmar Guest
17-04-2011, 12:02 Subject: TDI 1Z: Loud Knocking Noise at Idle |
For years, I've been hearing a loud, grinding noise on the left side of the engine (in the area of the serpentine belt), which is often drowned out by a metallic clanging sound.
If you increase the speed slightly, the noises disappear.
The car otherwise runs without any problems.
Is there anything specific about a diesel engine (with high mileage) that could cause this 'bearing noise'?
- If I remove the serpentine belt, the noise doesn't change.
- It's also not the tensioner or idler pulley for the timing belt.
What could that be?
Dietmar.
Translated on 03-09-2026, 23:21.
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
17-04-2011, 12:22 Subject: TDI 1Z: Loud Knocking Noise at Idle |
Vacuum pump?
Translated on 03-09-2026, 23:22.
Profile PM WWW Garage |
Wolf-Dietmar Guest
18-04-2011, 11:34 Subject: TDI 1Z: Loud Knocking Noise at Idle |
No, the vacuum pump is quiet.
It's coming from the side where the timing belt is.
'This 'rumbling' noise has become so loud that it might actually be coming from the crankshaft bearings.'
Does anyone have experience with which bearings, crankshaft bearings, or connecting rod bearings tend to wear out the most?
Translated on 03-09-2026, 23:23.
LZ Blaumann
Joined: 09/01/2003 Posts: 218 Karma: +6 / -0 Location: .at-Klbg.
18-04-2011, 13:39 Subject: TDI 1Z: Loud Knocking Noise at Idle |
Hello.
Get yourself a mechanic's stethoscope. It will be extremely helpful in diagnosing these kinds of issues!
Best regards, Roberto.
Wolf-Dietmar Guest
18-04-2011, 14:52 Subject: TDI 1Z: Loud Knocking Noise at Idle |
Yes.
I did that 30 years ago, but it doesn't help with the variety of noises in the TDI (in my case).
The water pump seems to be making a lot of noise, but the crankshaft bearing is also located there.
'Furthermore, I haven't noticed any oil or water leaks in the pump area, although the pump is still the original one.'
I thought I finally knew where it was coming from: the timing chain of the oil pump.
That would have been a good fit in terms of both the sound and the location.
But... the TDI doesn't have one at all.
And I can't imagine that the wave was caused by the oil pump being thrown off due to a timing belt that was too tightly tensioned.
Translated on 03-09-2026, 23:24.
Wolf-Dietmar Guest
20-04-2011, 18:46 Subject: TDI 1Z: Loud Knocking Noise at Idle |
Feedback.
Now I've listened to the car from underneath.
- It's the water pump that's making the noise.
Incredible quality for this part, 16 years old, wobbly like a lamb's tail, and yet it still doesn't leak any water.
Translated on 03-09-2026, 23:26.
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
20-04-2011, 20:36 Subject: TDI 1Z: Loud Knocking Noise at Idle |
Wolf-Dietmar wrote: | Feedback;
Incredible quality for this part, 16 years old, wobbly like a lamb's tail, and yet it still doesn't leak any water. |
I also had a similar experience with a Golf and a T3, after about 370,000 km, it was a wonderful thing that, despite a lot of use, it remained sealed!  NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 03-09-2026, 23:27.
Profile PM Email Garage |
