2.5 TDI R5 (ANJ 80kW) - Faulty fuel injection pump?
das-weberli
Post25-04-2011, 17:10    Subject: 2.5 TDI R5 (ANJ 80kW) - Faulty fuel injection pump? Quote
Hello everyone!
I'm having a small problem with a VW LT II, 5-cylinder TDI, 109 hp, engine: ANJ (first generation with VTG turbocharger).
The car was running normally until it suddenly started smoking like a badly tuned diesel engine and experienced a significant loss of power.
Here's what it looks like now:
It starts up fine and idles perfectly smoothly. When you give it gas, it responds well initially, but only revs up to around 2000 RPM and then experiences severe misfires or hesitations. It then goes into limp mode, the turbocharger obviously doesn't kick in anymore, the engine speed fluctuates wildly, and it makes a terrible knocking noise. Additionally, there is excessive smoke being produced.
Driving is impossible.
I initially thought it might be air in the fuel system or something like that...
However, this passes through the inflow line without any leaks.
The EGR valve is not working, the mass airflow sensor seems to be fine, and the turbocharger sounds loud.
Ah: No error codes found!
Translated on 11-07-2026, 12:39.
das-weberli
Post28-04-2011, 7:49    Subject: 2.5 TDI R5 (ANJ 80kW) - Faulty fuel injection pump? Quote
Fixed:
The throttle body vacuum valve has become detached.
Small cause, mega problem icon_wink.gif.
Translated on 11-07-2026, 12:40.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fuel Injector: Repair or Replace for 2.5 TDI? Diesel Engine Technology
No new posts A4 B6 2.5 TDI Fuel Injector Pump Failure Diesel Engine Technology
No new posts AKN Injection Pump Fault On-Board Diagnostics (OBD)
No new posts Audi TDI AEL: Faulty Fuel Injection Pump? Diesel Engine Technology
