Glow Plug Installation: Did I Do It Right?
exciter
Registered VCDS User
Post19-06-2011, 14:08    Subject: Glow Plug Installation: Did I Do It Right? Quote
I drive a B7 V6 TDI with the engine code BDG and I have installed Beru spark plugs.
Okay, I'm going to do a compression test on the car in the next few days because it's smoking when starting and doesn't start well in warm weather.
On my candles, it says:
Beru Germany 009
0 100 226 338
The part number seems to be correct, but what does the "009" mean?
For the V6 TDI engine, Beru lists the part number GN 008.
Is this just the revision number, and does it match my engine? Or are they the wrong parts, or are they counterfeit, etc.?
Best regards, Steffen.
Translated on 18-10-2026, 6:59.
exciter
Post19-06-2011, 15:05    Subject: Glow Plug Installation: Did I Do It Right? Quote
They probably are the right ones.
"009" likely indicates the year of manufacture, specifically 2009.
Can be closed.
Have a nice Sunday!
Translated on 18-10-2026, 7:00.
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Spark plug firing order Technical Data
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Which light bulbs are the right ones ??? Diesel Engine Technology
No new posts Misaligned Engine Mounts: Causes & Fixes Diesel Engine Technology
No new posts Installed an extra cable to protect the mass airflow sensor? Diesel Engine Technology
No new posts GRA lever installed - return ring clicks Transmission, Chassis, Body & Interior
