AFN: The infamous Kw screw
MrMcFly79
Post19-08-2011, 0:20    Subject: AFN: The infamous Kw screw Quote
Hello everyone,
"I had an incident with the KW bolt on my '96 Golf. Could this happen with all model years of the AFN engine? Or do later production years (in my case, a '99 Seat Ibiza with the AFN engine) have a stronger KW bolt and are therefore protected against this issue?"
Best regards from Tobi.
Translated on 25-10-2026, 14:00.
mdonau
1988 Audi 80
Post19-08-2011, 7:24    Subject: AFN: The infamous Kw screw Quote
Hi.
No, only the later models without the intermediate shaft received an M14 screw.
Installing a free-running system on the LiMa helps to reduce the stress on the connection.
Otherwise, the only solution is to regularly check and replace the screw and wheel.
Best regards, Michael.
Passat 3B AFN Syncro, E46 330D, T3 1,7TDI, T3-Syncro TD
Translated on 25-10-2026, 14:01.
vwSchrauber
Post19-08-2011, 17:13    Subject: AFN: The infamous Kw screw Quote
Only the successor models without an intermediate shaft received an M14 screw.
.....which, however, doesn't seem to be a 100% solution, as I know of an ALH engine where the screw came loose at 255,000 km icon_rolleyes.gif.
Translated on 25-10-2026, 14:02.
mdonau
1988 Audi 80
Post20-08-2011, 7:36    Subject: AFN: The infamous Kw screw Quote
vwSchrauber wrote:
Only the successors without an intermediate shaft received an M14 screw.
.....which, however, does not seem to be a 100% solution, as I know of an ALH engine where the screw came loose at 255,000 km icon_rolleyes.gif
"I think that, since the PD engine uses the same type of screw connection and there are many of this type of engine in use, we can consider these issues as isolated cases. This is quite different from the problems encountered with the older engines!"
"I have seen damage to the crankshaft bolt on many engines from the older 1.6 and 1.9 generations, and I have even repaired some of them. However, I haven't encountered any problems with the crankshaft bolts on the newer engines."
PD elements integrated into the timing chain and worn camshafts are more likely to be found in such cases.
Translated on 25-10-2026, 14:04.
MrMcFly79
Post20-08-2011, 22:53    Subject: AFN: The infamous Kw screw Quote
Hmm, shouldn't my alternator already have a freewheel?
Translated on 25-10-2026, 14:05.
Boro
Post22-08-2011, 6:30    Subject: AFN: The infamous Kw screw Quote
Does it have icon_biggrin.gif? If it's defective or stuck, the belt vibrates quite a bit.
No new posts A3 8L Screw Corrosion: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts KW Coilover Screw: Buy Now! Diesel Engine Technology
No new posts External Tooth Screw: Buy Now! Diesel Engine Technology
No new posts VA Screw in Manifold: How to Remove? Diesel Engine Technology
No new posts Screw broken off in the turbocharger Diesel Engine Technology
