ARL Noises: Troubleshooting Cold Start Issues
g1om
Post28-10-2011, 19:26    Subject: ARL Noises: Troubleshooting Cold Start Issues Quote
Good evening.
I've been experiencing a rattling/tinkling sound in my ARL Leon for quite some time, especially when the engine is cold.
The sound is unfortunately very difficult to describe; it's somewhat like faulty hydraulics, but with a slightly higher-pitched ringing. I've tried recording it several times, but unfortunately, all that can be heard is the diesel engine noise, and the other sound is not discernible.
The noise only occurs when the engine is cold, at an RPM of 2200-2500 RPM. It doesn't happen under light load until the coolant temperature reaches approximately 70 degrees Celsius, and not in full acceleration. If the engine is pre-heated for a long time using the auxiliary heater, the noise doesn't occur at all.
There is nothing saved in the FS.
No irregularities were detected in MWB units 13 and 23 during the warm-up phase.
In general, I couldn't say that I found anything else that could explain it, except perhaps I have 'shrink sleeves' icon_confused.gif.
I also think it's possible for the elements to have a poor spray pattern.
The camshaft and lifters are in good condition and show no signs of wear.
My dealer just said, 'We need to take the cylinder head off' icon_question.gif and then icon_question.gif.
'Messen' icon_exclaim.gif AHHH yes.
Right now, with the cold weather, I'm starting to get really annoyed with this, and I'd like to turn it off. Do you have any ideas about where else I could look into this?
Thank you in advance.
Translated on 14-09-2026, 5:14.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post28-10-2011, 19:28    Subject: ARL Noises: Troubleshooting Cold Start Issues Quote
"How many kilometers are on it? For me, the hydraulic lifters needed to be replaced at around 160,000 km. They weren't making a clanking noise, but rather a ticking/snapping sound. (Not all of them fail at the same time, of course)."
reflexsilber met.
Translated on 14-09-2026, 5:16.
Post29-10-2011, 8:12    Subject: ARL Noises: Troubleshooting Cold Start Issues Quote
What kind of engine oil is being used? Or, to put it another way, do the oil specifications and viscosity match the manufacturer's recommendations?
Translated on 14-09-2026, 5:17.
g1om
Post29-10-2011, 18:09    Subject: ARL Noises: Troubleshooting Cold Start Issues Quote
Currently, I have 130,000 km on the odometer, but I needed a complete engine head replacement at 76,000 km, which cost a fortune icon_evil.gif.
'If the catalytic converters were defective, I would hear the noise even when preheating the engine with the auxiliary heater. If I don't preheat, I can drive about 4-7 kilometers before the noise becomes audible, but only within that engine speed range of 2200-2500 RPM.'
Regarding the oil: I've always used 5W40 PD oil without the 'longlife' specification from a reputable manufacturer, and I haven't had any problems with it.
Translated on 14-09-2026, 5:18.
RedR32
Avatar-RedR32
Post29-10-2011, 19:44    Subject: ARL Noises: Troubleshooting Cold Start Issues Quote
Try recording the sound again; then we might be able to assess it better.
reflexsilber met.
No new posts Doku 4-cylinder. TDI Clattering/Rumbling, Power Loss Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8L MJ 1999: Rattling/Humming Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Acoustic Noise Analysis: Identifying and Locating Sources... General Tips
No new posts 1.9 TDI PD: Cold Start Problems & Solutions Diesel Engine Technology
No new posts Vacuum in Cold Conditions Diesel Engine Technology
No new posts CFFB Shakes in Cold Weather Diesel Engine Technology
No new posts Golf ALH - Relais schaltet ständig im kalten Zustand Diesel Engine Technology
