Fake Mileage: Ibiza 6L Car Problems
fazi
Post14-09-2011, 10:05    Subject: Fake Mileage: Ibiza 6L Car Problems Quote
Hello everyone...
I'm having the following problem with this vehicle (Seat Ibiza 6L, year of manufacture: 2008, engine code: BTS).
After the vehicle had been idle for approximately 3-5 months and the starter battery was completely dead, the odometer reading on the instrument cluster showed about 20,000 km less after replacing the battery. However, the trip meter and odometer function correctly during normal driving.
Mileage displayed on the instrument cluster: 12,687 km.
Effective mileage = approximately 31,700 km.
"Does anyone else experience this issue? Is it possible to increase the mileage reading using VCDS to match the actual mileage? Do you need any further information about the vehicle?"
Thank you in advance for your suggestions.
Translated on 11-08-2026, 21:22.
Post14-09-2011, 10:48    Subject: Fake Mileage: Ibiza 6L Car Problems Quote
Unfortunately, nothing can be done with VCDS in this case.
Even the friendly one can't do anything about it.
Translated on 11-08-2026, 21:24.
dieselschrauber likes this.
Post14-09-2011, 10:57    Subject: Ibiza 6L: Incorrect Mileage - Problem? Quote
fazi wrote:
Mileage on the AI display = 12,687 km.
Does anyone know this problem?
Could the display showing "10,000" be defective in such a way that only the two rightmost segments of the digit "3" are lit up?
No.
Translated on 11-08-2026, 21:25.
Post14-09-2011, 10:57    Subject: Fake Mileage: Ibiza 6L Car Problems Quote
If the manufacturer/importer is unwilling to offer any goodwill or compensation, then a new combination instrument is likely the only option.
Translated on 11-08-2026, 21:26.
Post14-09-2011, 11:03    Subject: Fake Mileage: Ibiza 6L Car Problems Quote
ulf wrote:
Could the 10,000 display be defective in such a way that only the two rightmost segments of the digit '3' are lit up?
This can be checked with a segment test. However, I believe that the display control was designed in such a way that if this were the case, other segments would likely fail as well.
Post14-09-2011, 13:43    Subject: Fake Mileage: Ibiza 6L Car Problems Quote
...leave it for just two months and you'll have a brand new car icon_smile.gif.
Translated on 11-08-2026, 21:27.
No new posts Used Porsche Mileage: What to Look For General Tips
No new posts Audi A3 (8L): High Mileage Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Electrical problem in wet conditions, Seat Ibiza 6L ASZ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Invalid Authorization Code: Causes & Fixes Dieselschrauber Bar
No new posts Airbag Control Unit Replacement: Incorrect Index? On-Board Diagnostics (OBD)
No new posts Check Passat 3BG mileage Electrical Systems, Vehicle Electronics, Multimedia
No new posts Wahren Kilometerstand auslesen On-Board Diagnostics (OBD)
