Replacing rear brake discs on a G3 - difficult?
Post24-03-2003, 21:49    Subject: Replacing rear brake discs on a G3 - difficult? Quote
Hello everyone.
I need to replace my rear windshields sometime.
Unfortunately, they aren't screwed onto the hub, but are instead part of the hub itself, into which, according to my repair manuals, the outer bearing rings are also pressed.
You have to use a hammer and a nail to get them out and put them back in.
"In practice, would medium-sized hammers, weighing up to about 300 grams, and a set of punches with a diameter of up to about 4 mm be sufficient for the work?"
"Does it often break, so that I should probably buy the relevant parts (which ones?) at the same time?"
How is the ABS sensor ring attached to the disc/hub?
Thank you for any assistance!
felix
Avatar-felix
Post25-03-2003, 9:56    Subject: Replacing rear brake discs on a G3 - difficult? Quote
Hi Ulf,
Taking the pallets out and putting them back in is not particularly difficult.
If the bearings have already been used for a long time, you might as well replace them with new ones. They're not that expensive, and I wouldn't want to have to do the same work again in about 10,000 km. When replacing a bearing, the seal is usually included, and it often suffers damage during the removal process anyway.
However, if possible, I would use aluminum studs, as this reduces the risk of damaging the tire treads. Unfortunately, I don't have any information about the ABS ring. I assume it's screwed on.
Gruß Felix
E91 330d, 1/2009
Andy
Post25-03-2003, 10:32    Subject: Replacing rear brake discs on a G3 - difficult? Quote
The ABS ring is simply attached and can be easily removed, cleaned, and reattached to the new disc.
Andy.
Mc_Givertechnik
2010 Volkswagen T5
Post25-03-2003, 12:57    Subject: Replacing rear brake discs on a G3 - difficult? Quote
Hello Ulf!
As mentioned above, removing and reinstalling the brake disc is not difficult. The choice of brake discs is more important. I would not use "no-name" discs. At a minimum, you should use ATE discs and pads. Although the braking force on the rear wheels is relatively low, I have often encountered vehicles that, after half or a normal lifespan, returned with completely worn-out brake discs.
Even with branded brake rotors, the mounting points are more precise; there's no risk of the rotor getting stuck or being forced into place (I've seen it all). On my Galaxy, I applied new brake pads to the front and rear, and I masked off the areas that contact the brake disc and the rim icon_mad.gif, then painted them with brake paint (silver, of course, not red or any other color ). This worked very well; there was no rust, and they always looked like new. Even the ventilation channels of the front ventilated brake discs were painted. I've seen brake discs that were completely rusted on the fins between the ventilation channels, causing them to break apart. The rest of the car didn't look good at all, but I think the guy might be able to get it running again.
Of course, it's just a bit of fun, but it's worth it for vehicles that sit around for a long time.
Greetings from Graz, Peter.
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Post26-03-2003, 20:04    Subject: Great. Quote
Then I'll get around to it soon.
haehnlein
Post27-03-2003, 21:26    Subject: Replacing rear brake discs on a G3 - difficult? Quote
Hi Ulf,
I don't know which brake system you have, but please check the two guide pins of the brake caliper icon_exclaim.gif. They tend to rust and seize over time, which can quickly cause new rotors to rust icon_exclaim.gif. So, a little grease and a new rubber boot won't hurt icon_exclaim.gif. Which tool did you buy to retract the rear brake piston?
Best regards, Christian.
____________
Kein Auto mehr!
felix
Avatar-felix
Post28-03-2003, 12:54    Subject: Replacing rear brake discs on a G3 - difficult? Quote
I wouldn't buy a special tool for turning the piston back for personal use. I do it with a large C-clamp to apply some pressure, and then turn the piston back using a wrench. You have to constantly adjust the C-clamp and be careful not to damage the dust seals. It's a bit fiddly, but it's doable.
Gruß Felix
E91 330d, 1/2009
haehnlein
Post28-03-2003, 20:38    Subject: Replacing rear brake discs on a G3 - difficult? Quote
Hi Felix,
I have successfully pushed the brake pistons back twice using a suitable disc and round steel rod with a rotating motion and simultaneous pressure icon_wink.gif. However, a member of the forum had something to complain about:
Okay, I'm ready. Please provide the German text you want me to translate.
____________
Kein Auto mehr!
felix
Avatar-felix
Post29-03-2003, 11:49    Subject: Replacing rear brake discs on a G3 - difficult? Quote
Hi Christian,
Of course, you're not allowed to damage anything, and you shouldn't apply too much pressure. But if you proceed carefully, it can also be done without special tools.
Because the specialized pliers can only do so much, namely icon_wink.gif squeeze and rotate. So, let's continue like this.
Gruß Felix
E91 330d, 1/2009
christians
Post29-03-2003, 21:12    Subject: Replacing rear brake discs on a G3 - difficult? Quote
I'm doing it exactly the same way as Felix.
You just have to avoid being too hasty, otherwise you might end up accidentally damaging a cufflink.
Gruß Christian
Post31-03-2003, 19:21    Subject: Replacing rear brake discs on a G3 - difficult? Quote
haehnlein wrote:
Which tool did you buy to retract the rear brake caliper pistons?
Hi Christian,
not at all... I'll first try to push the piston in by screwing it in with a suitable flat bar or something similar icon_confused.gif.
If that doesn't work, I'll reassemble everything as it was and look for a cheap tool solution.
Timing isn't a major concern for this project (the TÜV inspection was completed last fall).
haehnlein
Post01-04-2003, 12:10    Subject: Replacing rear brake discs on a G3 - difficult? Quote
Hi Ulf,
You can do without the tool... (I bought one once, but it doesn't fit our Audi icon_evil.gif)... and as I said, make a suitable plate with a "handle," then only loosen one screw on the brake caliper, open it up, and with pressure and a twist, it's really not a problem at all icon_wink.gif.
____________
Kein Auto mehr!
Post01-04-2003, 16:14    Subject: Replacing rear brake discs on a G3 - difficult? Quote
haehnlein wrote:
Make a suitable plate with a "handle", then loosen the brake caliper on just one screw, open it up, and with pressure and a twisting motion, it's really not a problem at all icon_wink.gif
Hi Christian,
It's good that the TDI doesn't stand out too much icon_twisted.gif.
No new posts Audi A4 B6 Rear Door Won't Unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T6, rear shock absorbers - replacement / weak performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Brake Pads Replacement Rear Axle Transmission, Chassis, Body & Interior
No new posts Replacing rear brake discs and pads! Transmission, Chassis, Body & Interior
No new posts Rear Brake Discs 2.0 TSI Replacement Transmission, Chassis, Body & Interior
No new posts Passat 35i: Replace Rear Brake Discs Transmission, Chassis, Body & Interior
