How to disable the "trunk open" warning sound
Medieval
2021 Volkswagen T-Cross
Post09-09-2011, 16:44    Subject: How to disable the "trunk open" warning sound Quote
Hello fellow DIY enthusiasts,
"Occasionally, due to the load in my VW Caddy (year 2008), I can't fully close the tailgate. This triggers an annoying warning sound every time I start the engine. Sometimes it happens when the tailgate is only latched, and on bumpy roads, the warning sound continues incessantly, which is very irritating. I would be satisfied with a simple "tailgate open" indicator on the display." Is there a way to disable the sound in the encoding process?
Thank you.
Max.
Post09-09-2011, 17:02    Subject: How to disable the "trunk open" warning sound Quote
You must have secured the lid somehow so that it doesn't open completely.
Simply engage the bolt (or the key blade) into the door latch mechanism twice, and then the Caddy will think it has the rear end locked. icon_wink.gif
Before closing the door after unloading, make sure to pull the release handle first; otherwise, it will slam shut with a loud bang when you close the door onto the lock.
The luxury version:
Place a climbing carabiner in your lap and then use the carabiner to secure the gate.
 Halteöse für Heckklappe
 File size:  63.31 KB
 Viewed:  11781 times
Medieval
Post09-09-2011, 17:14    Subject: How to disable the "trunk open" warning sound Quote
You're welcome, dieselmartin.
It's a good idea overall, especially the part about the carabiner, great! My next purchase: a carabiner hook! icon_wink.gif
I hadn't even thought of that, but if the lock isn't fully engaged, this version no longer works. I would prefer a complete shutdown.
Does anyone have any advice?
Max.
Post09-09-2011, 17:21    Subject: How to disable the "trunk open" warning sound Quote
It can't be done with software; either it's like Martin said, or you need to disconnect the plug from the lock.
Medieval
Post09-09-2011, 17:25    Subject: How to disable the "trunk open" warning sound Quote
"Is that not possible? That's a shame."
Then the plug is going to get damaged, but I'm still going to buy the carabiner.
Thank you!
Max.
VW T-Cross 2021
Octavia_4x4
Post18-09-2011, 11:35    Subject: How to disable the "trunk open" warning sound Quote
If the plug is disconnected, the interior light in the trunk also stops working icon_wink.gif.
Ross-Tech-Support
Post18-09-2011, 12:31    Subject: How to disable the "trunk open" warning sound Quote
...and if the connector is disconnected, you may also generate error messages, and any potentially installed vehicle communication system may also be out of function.
In my opinion, the solution using a double locking mechanism or, more specifically, a carabiner, is the most optimal for occasional transport, as it eliminates the error message. I think it's suboptimal to go through the trouble of unplugging it – there are too many disadvantages.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Open Trunk/Hatch: Light Indicator On On-Board Diagnostics (OBD)
No new posts "Rear lid open" indicator Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi A3: Door Open & Ignition Warning? On-Board Diagnostics (OBD)
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
