Seat Alhambra, MSG disabled (RESOLVED)
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
stsch
Post10-09-2011, 20:23    Subject: Seat Alhambra, MSG disabled (RESOLVED) Quote
I have a problem with my Alhambra. The MSG is locked in VCDS, so I wait about an hour and then I can access it again. Furthermore, the vehicle does not start until I have access to the MSG again. I drive for a short distance until the engine is slightly warm, turn it off and wait for about 5 minutes, and then I cannot start it and I also cannot access the MSG. When I read the MSG, it shows an error. For the Seat Alhambra 1.9 TDI, manufactured in 1997.
Back to top Profile PM Email
Post10-09-2011, 21:00    Subject: Seat Alhambra, MSG disabled (RESOLVED) Quote
Either the engine control unit (ECU) is not functioning (e.g., due to soldering/contacts inside), or it is not receiving any power (search for relay 109).
Hi, Rainer
stsch
Post10-09-2011, 21:22    Subject: Seat Alhambra, MSG disabled (RESOLVED) Quote
Hello Rainer,
I have replaced the vacuum hose on the engine control unit and checked the soldered connections. Is Relay 109 also responsible for preheating?
Stefan
Post11-09-2011, 9:42    Subject: Seat Alhambra, MSG disabled (RESOLVED) Quote
Unfortunately, I don't know the Alhambra in detail. The relay doesn't necessarily have to have the marking "109".
In all cases, however, it refers to the relay for power supply to the engine control unit. Since the engine control unit in your car controls the pre-heating, nothing will happen without power.
Possible causes include a faulty ignition switch and/or a blown fuse in the fuse box.
Z.B.:
/viewtopic.php?t=23242&highlight=relais+109
Hi, Rainer
stsch
Post21-09-2011, 18:26    Subject: Seat Alhambra, MSG disabled (RESOLVED) Quote
Hi everyone,
The problem was with relay 109. The PCB had a cold solder joint, a new relay was installed, and the vehicle now runs and starts properly again.
Greetings and thank you
Stefan
Post21-09-2011, 19:58    Subject: Seat Alhambra, MSG disabled (RESOLVED) Quote
BM
Avatar-BM
Post21-09-2011, 20:07    Subject: Seat Alhambra, MSG disabled (RESOLVED) Quote
3B5 AJM
No new posts Golf3 pulls to the left (SOLVED) General Tips
No new posts Broken sun visor clip for Audi, Seat, Skoda, VW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Electrical problem in wet conditions, Seat Ibiza 6L ASZ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Alhambra 2.0 TDI constantly regenerating Diesel Engine Technology
No new posts Problems with Micro-Can on Seat Alhambra On-Board Diagnostics (OBD)
No new posts Seat Alhambra: Sliding Door Auto Close Coding On-Board Diagnostics (OBD)
No new posts Fixing a car with a corrupted system / Seat Alhambra 2014 On-Board Diagnostics (OBD)
