Mc_Givertechnik Schrauber
Joined: 02/27/2003 Posts: 390 Karma: +3 / -0 Location: Graz Österreich 2010 Volkswagen T5 Premium Support
27-03-2003, 10:58 Subject: OBD II Tuning: How to Tune Your Car |
Hello!
Immer wieder stolpere ich über Seiten, auf denen Tuning über die OBD II Schnittstelle angeboten und verkauft wird. Das kann ja nicht sein? Oder doch? Meines Wissens nach, befinden sich die Kennfelder und die dazugehörigen Einstellungen auf einem gebrannten Eprom (oder ähnlichem), also wie soll das gehen. Oder nutzen die die minimalen Verstellmöglichkeiten aus? Nur wie bringen die das dann zusammen, bei einem ACV eine Mehrleistung von 30 PS zu erreichen. Is Give me a riddle.
Has anyone here ever dealt with this topic before?
Regards, Peter. VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Translated on 28-09-2026, 11:48.
Profile PM Email Garage |
DaBibo Blaumann
27-03-2003, 13:46 Subject: SEO: Best German to English Translation Services |
The diagnosis, for example using VAG COM, is done via the K/L line. If you have a proper CAN-BUS interface, I can imagine that you might be able to modify the software in the control units.
31-03-2003, 14:37 Subject: OBD II Tuning: How to Tune Your Car |
Translated on 28-09-2026, 11:49.
Rudi Guest
31-03-2003, 15:02 Subject: OBD II Tuning: How to Tune Your Car |
Hello Peter,
They are using the same forum software as Rainer.
In my opinion, there's nothing wrong with it.
Best regards, Rudi.
Translated on 28-09-2026, 11:50.
zzzZZ Guest
31-03-2003, 15:04 Subject: OBD II Tuning: How to Tune Your Car |
What do you mean by 'rip-off' or 'copy'?
They're just running a forum that uses the same software (phpBB) provided by the same vendor. That's why the layout is so similar.
01-04-2003, 7:07 Subject: OBD II Tuning: How to Tune Your Car |
Hi everyone!
Okay, now I understand, and that's a good thing. I was just wondering if it was the right thing to do. I also didn't know that the surface for a forum could be resold multiple times; I wasn't aware of that. As I said, you never stop learning.
However, let's get back to the topic. I was able to view the page, but since my Polish is limited, I couldn't understand anything.
What about OBD tuning? Does it use the same adapter but different software, or a different adapter and software? Who performs it? What are the consequences for the engine? Who has extensive experience with it? How does the cost compare to traditional chip tuning, which involves working directly on the engine control unit and installing a new EEPROM? Are there any reputable companies that offer this service? So many questions...
Thank you very much, best regards.
Translated on 28-09-2026, 11:52.
Stefan Guest
01-04-2003, 8:32 Subject: OBD II Tuning: How to Tune Your Car |
It doesn't work with the existing adapter, nor with VAG-COM.
You need specific hardware and software for this, which is extremely expensive.
But why don't you ask your tuner? He will certainly be able to explain the differences to you.
Tuning via OBD is quick and easy, but it's not always the best option.
Technically speaking, OBD tuning is the same as 'conventional' chip tuning.
Translated on 28-09-2026, 11:53.
