Chewing Gum: Car Seat Stains & How to Remove (Solution)
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » General Tips
Karma: +805 / -0   Thank you, like it!
Post01-08-2010, 10:22    Subject: Chewing Gum: Car Seat Stains & How to Remove Quote
Chewed gum and low-quality, sun-heated (melted) balloons have three things in common:
- they are partially made of rubber.
- They adhere particularly well to fabrics, such as those used in trousers or car seat upholstery.
- They are difficult to remove with standard cleaning methods (washing).
It's even worse when, while parking in the summer heat, a child's balloon bursts and its fragments get embedded in the fabric of the rear seat, or when you sit on chewing gum at the cinema and unknowingly spread it further into the upholstery.
After some online research and unintentional experiments involving chewing gum and balloons, the following methods have proven to be successful:
- Chewing gum can be removed from pants by freezing the pants in the freezer until they are hard, and then manually "digging" it out.
- Removing the upholstery fabric in car seats is not so straightforward, as it requires a significant amount of effort. In this case, commercially available silicone removers, plastic spatulas, and paper towels can help. After removing everything, you can completely remove stains and chemical residue by using plenty of clear water, scrubbing, and vacuuming (use an old vacuum cleaner!).
I have had good experiences with SOUDAL's silicone remover, especially when dealing with a burst balloon. The product comes with a plastic spatula. The green balloon was so easily removed from the upholstery fabric that absolutely nothing is visible anymore.
The following information also reached me:
Another method, which only works with fabric upholstery and genuine leather, would be to freeze the stain using dry ice or liquefied gas (from a lighter refill).
Both methods are very inexpensive and, when used correctly, are also relatively safe.
Good ventilation and no open flames are a given. Similarly, the immediate destruction (due to the risk to children and the possibility of frostbite) of dry ice is essential. The amount of lighter gas released is harmless and dissipates very quickly.
I had previously tried using 'freezing', but it failed due to the staining effect of the balloon (the padding was green) and the 'massaging' that had already been done on the fabric. icon_smile.gif However, it might work better with chewing gum.
Good luck, Rainer.
Translated on 30-08-2026, 23:35.
Ratings - Chewing Gum: Car Seat Stains & How to Remove
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Passat 3C or Superb 3T emergency unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts S3 or S4 seats in an Audi 80 or other sports seats? Transmission, Chassis, Body & Interior
No new posts Immobilizer system, version 2 or 3 / with or without CAN ... On-Board Diagnostics (OBD)
No new posts TDI 110/115 PS: Specs & Performance Diesel Engine Technology
No new posts WBK vs. TDI: Which is Best? Diesel Engine Technology
