The differential pressure sensor and the DPF loading status cannot be adjusted via diagnostic adaptation for the 2.7L V6 CR TDI engine control unit.
Therefore, it is not possible to calibrate the differential pressure sensor or reset the ash mass of the diesel particulate filter.
Verified with engine control unit:
4F1910401B 2.7L V6 TDI G000SG 0030
Solution:
Update to software version 0060. See TPI 2012786/8, SVM code 4F01A016.
See also:
Engine control unit, new engine software, CD number, SVM (Software Vehicle Module).
4E0910402B, 4E0910402B_0040, 4E0906961Q, 4E01A009
0010 0020 0030
4E0910402C, 4E0910402C_0030, 4E0906961Q, 4E01A009
0010 0020
4E0910402G, 4E0910402G_0030, -----------------, 4E01A012
0020
4E0910402H, 4E0910402H_0020, --------, 4E01A012
0010
4F0910401S, 4F0910401S_0050, 4E090696Q, 4F01A016
0020 0030 0040
4F0910402E, 4F0910409C_0010, -----------------, 4F01A023
0010
Translated on 17-09-2026, 23:44.
