Passat combination instrument cluster, year 1998
schlosser79
Registered VCDS User
Post16-01-2012, 16:28    Subject: Passat combination instrument cluster, year 1998 Quote
"Hi, the combination lock on my Passat is broken. I've now bought a new used one and wanted to have the immobilizer programmed at VW, but they say it's not possible because the VIN of the previous owner is still in the system! They told me I need to have the memory erased..."
Can this be done with VAGCOM without clearing the memory? Where is the login code located, or does it need to be obtained from VW?
Translated on 16-07-2026, 19:55.
Post16-01-2012, 16:33    Subject: Passat combination instrument cluster, year 1998 Quote
schlosser79 wrote:
Is it possible to do this with VAGCOM without clearing the memory?
Yes, if a login is available.
schlosser79 wrote:
...where is the login code located?...
It's on the small plastic tag, which usually isn't there anymore. VW doesn't provide any physical documentation; everything is online.
Edit: Could someone please provide the part number for the "new" AI? It seems like it might be the wrong one!
Translated on 16-07-2026, 19:56.
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Software error in the instrument cluster - workshop action Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Kombiinstrument Passat Modell 2001 Diesel Engine Technology
No new posts Passat 3B - Issues with Comfort Control Unit / Instrument... On-Board Diagnostics (OBD)
No new posts Passat 3c Wagon: Speedometer "fluctuates" On-Board Diagnostics (OBD)
No new posts Audi A4 8E Kombi Instrument 2.5 TDI AKE On-Board Diagnostics (OBD)
