T5 TDI AXE: Diesel Additive & Oil Problems
Gremlin
Avatar-Gremlin
Karma: +92 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Post22-07-2011, 12:25    Subject: T5 TDI AXE: Diesel Additive & Oil Problems Quote
Hello everyone,
As a "hobbyist" or "occasional mechanic," one unfortunately doesn't have much experience with the various potential causes [of a problem].
Lt. Search.
- Tandem pump
- PDE sealing rings
- Cylinder head worn out, PDE (presumably a specific component or modification) installed.
Here's the translation:
It's a VW Transporter (Type 7HK), 2.5L TDI, 172 hp, 4-Motion (all-wheel drive), no modifications, 142,000 km.
Diesel additive (oil change according to VW 506.01, 0W30) - add 3 liters of diesel after approximately 3500 km (approximately 11 liters will be drained in total).
The system was depressurized. The tandem pump is leaking. The valve cover was removed. The system was depressurized again. There is diesel contamination in cylinder 2 (at least, that's what appears on the display after a short time, indicating element 2).
My question:
-Can a PDE (pressure drop element) itself be defective (leaky), or is that rather unlikely?
Off-Topic:
Currently, the vehicle is at a free workshop that has a VCDS license. If I need to ask you experts any questions using VCDS (e.g., regarding the parking brake system), do I need to enter the workshop's license number in my profile? Is that correct?
Translated on 26-10-2026, 12:03.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post22-07-2011, 23:31    Subject: T5 TDI AXE: Diesel Additive & Oil Problems Quote
You were probably just lucky!
The relevant PD elements are known.
You can have them resealed.
Most likely, a new head will be needed.
Translated on 26-10-2026, 12:06.
vp37
2003 Volkswagen T5
Post27-07-2011, 13:32    Subject: T5 TDI AXE: Diesel Additive & Oil Problems Quote
I completely agree.
VCDS und KTS 670 User
Gremlin
Avatar-Gremlin
Post26-10-2011, 15:48    Subject: Feedback: New Problem & Solution Quote
Hello everyone;
First, some feedback:
I randomly got a used head (with less than 100,000 km); since then, it's been quiet - thankfully. icon_smile.gif
Next problem:
He somehow damaged the oil pan; what's the best way to get it off?
Does this require the removal of the angular drive or similar components?
As described above:
VW Transporter (Type 7HK), 2.5L TDI 172 hp 4-Motion (long wheelbase).
EDIT:
***shit***
Sorry, it had to be said.
The angle gear needs to be removed, or at least loosened somehow. About 5 of the oil pan screws at the rear are very difficult to access. Of those 5, about 3 can be removed with some assistance, but there's a 0.00% chance of removing the other 2.
It's not that simple working on a homemade pit in your garage...
Translated on 26-10-2026, 12:08.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post28-10-2011, 15:50    Subject: T5 TDI AXE: Diesel Additive & Oil Problems Quote
He somehow damaged the oil pan; how can I get it off most easily?
What happened?
reflexsilber met.
Translated on 26-10-2026, 12:09.
Gremlin
Avatar-Gremlin
Post28-10-2011, 16:08    Subject: T5 TDI AXE: Diesel Additive & Oil Problems Quote
Don't ask me - I don't know; it's not mine, it belongs to my brother-in-law.
Somewhere in the area (there's a fish pond), he apparently got "stuck" a bit, even though the bank is already quite high.
"I guess I'll have to deal with the consequences..."
Regarding the "transmission problem" we were just talking about:
New topic.
Ich kann den Inhalt dieser URL nicht abrufen, da ich keinen Zugriff auf externe Websites habe. Bitte gib mir den Text, den du übersetzt haben möchtest.
Translated on 26-10-2026, 12:10.
Gremlin
Avatar-Gremlin
Post04-01-2012, 15:45    Subject: Adjusting Spur Gear Drive: How-to Guide Quote
Gremlin wrote:
VW Transporter (Type 7HK), 2.5l TDI 174HP
Hello everyone;
the same engine, just a different "housing" icon_wink.gif.
Year: 2003, Mileage: 164,000 km, cylinder head needs to be replaced...
Everything was rebuilt (I bought a bare head from a motor repair specialist), and even the hydraulics and camshaft were in good condition, which surprised me.
My question:
During assembly, the lateral play of the timing chain on the crankshaft is adjusted using an eccentric fitting located on the side of the cylinder head.
Does anyone have a short "how-to" guide for the workflow?
EDIT:
Here's a quick question on the side:
Unfortunately, the PDE also exhibits some "roughness" at the point where it was integrated into the head.
Should those be replaced? The idle speed control was generally fine, except for cylinder 3 (which was slightly higher, about 0.icon_cool.gif.
Or do I just install it and it will work?
Translated on 26-10-2026, 12:12.
RedR32
Avatar-RedR32
Post04-01-2012, 20:23    Subject: T5 TDI AXE: Diesel Additive & Oil Problems Quote
Special tools are required for this, such as a tool to securely hold the inner wheel (NW wheel) and the eccentric.
Important: Pay attention to the markings during assembly. The eccentric bolt should be carefully pre-tensioned counter-clockwise and then secured. The housing cover must be temporarily screwed on beforehand for centering.
After the PD wiring harness has been installed, the housing cover can now be permanently attached with sealant. Next, attach the PD connectors, the closing cover for the eccentric bolt, and screw in the Hall sensor. Insert the NW wheel, paying attention to the markings, start threading the screw, but do not tighten it yet. Attach the clamping tool, tension it against the direction of motor rotation, and tighten the NW screw almost to the clamping force. Now, use the larger NW wheel clamping device to finally tighten the NW screw.
I would inquire with VW for the current torque specifications for clamping, tensioning, and screwing.
reflexsilber met.
Translated on 26-10-2026, 12:15.
No new posts Debris and fragments in engine oil bind General Tips
No new posts Motor oil for PD with WIV? Diesel Engine Technology
No new posts Motor Oil for 2.0 PD TDI (BMN) Diesel Engine Technology
No new posts Best Engine Oil: Which One to Choose? Diesel Engine Technology
No new posts Which engine oil for WIV? Diesel Engine Technology
