Skoda Octavia 1Z5 RS Cornering Light
Octavia_4x4
Post14-12-2012, 10:50    Subject: Skoda Octavia 1Z5 RS Cornering Light Quote
I couldn't find anything in the search. Does anyone know the coding for the body control module (BCM) to disable the cornering lights that are integrated with the fog lamps on RS models from 2010 onwards?
The vehicle has xenon headlights with cornering lights and LED daytime running lights. Unfortunately, I can't perform a scan right now; I won't be able to see the car until Saturday.
Translated on 19-07-2026, 21:25.
Post14-12-2012, 11:07    Subject: Skoda Octavia 1Z5 RS Cornering Light Quote
If you don't know how the rest of the car is configured/equipped, how can you determine a coding setting in advance? icon_rolleyes.gif
The easiest way is to go to the body control module (address 09) and check the corresponding box; it takes about 2 minutes.
Translated on 19-07-2026, 21:27.
Post14-12-2012, 11:51    Subject: Skoda Octavia 1Z5 RS Cornering Light Quote
MJ 10 - which is an A in the FIN exam.
Then he already has a BCM.
I would say LC, 14.7.
Octavia_4x4
Post14-12-2012, 19:51    Subject: Skoda Octavia 1Z5 RS Cornering Light Quote
I managed to do it... I'm still very inexperienced, but I realized that VCDS basically tells you everything to do. That probably comes from only ever reading error codes or coding a really old control unit before.
Translated on 19-07-2026, 21:28.
Post14-12-2012, 19:55    Subject: Skoda Octavia 1Z5 RS Cornering Light Quote
Thank you for the feedback icon_wink.gif.
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Golf IV / Octavia 1 Water ingress at the doors Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Octavia 1.9: Specs, Problems, & More On-Board Diagnostics (OBD)
No new posts Skoda Octavia BKC: Cold Start Problems Diesel Engine Technology
No new posts Skoda Octavia 5E battery coding Electrical Systems, Vehicle Electronics, Multimedia
No new posts Relay for Skoda Octavia 1U5 Electrical Systems, Vehicle Electronics, Multimedia
