Throttle valve - error
Go to page: 1, 2  Next
engl
Post10-01-2012, 14:56    Subject: Throttle valve - error Quote
I've been having a problem with my Touran for days now.
The exhaust diagnostics program indicates:
P2100 Throttle control actuator - circuit open.
P2102 Throttle control actuator - low voltage in the engine circuit.
At first, I thought the problem was related to the engine wiring harness; however, after replacing it yesterday, I tried to clear the error code today and realized that it likely has a different origin.
Since this error is likely not occurring only on my system and has already been discussed in the forum, I would appreciate it if you could tell me what keywords to search for. Thank you.
Translated on 17-07-2026, 11:02.
Post10-01-2012, 15:14    Subject: Throttle valve - error Quote
Please explain why you replaced the wiring harness. Were there any other problems?
Has the error already been fixed, and is it reappearing immediately?
What does that thing do in the actuator diagnostics?
Translated on 17-07-2026, 11:05.
Post10-01-2012, 15:22    Subject: Throttle valve - error Quote
Have you already read this? (Referring to the link: /viewtopic.php?t=26037&highlight=bkd)
Translated on 17-07-2026, 11:06.
engl
Post10-01-2012, 15:23    Subject: Throttle valve - error Quote
''Please explain why you replaced the wiring harness. Were there any other problems?'
'What does that thing do in the actuator diagnostics?'
Switched because: The Touran occasionally jerked, especially when towing a trailer.
Further issues: Upon closer inspection, I think the engine hesitates slightly when idling; in my opinion, this is related to the intake manifold control valve.
Could it be referring to the 'throttle valve'?
Deleted: The error reappears immediately, yes!
I can't perform the actuator diagnosis myself; I have to wait until Thursday to take it to the dealership.
Translated on 17-07-2026, 11:09.
Post10-01-2012, 16:00    Subject: Throttle valve - error Quote
The intake manifold valve and the throttle valve are the same thing in the EURO4 standard.
The previous ones don't have a throttle, so the butterfly valve in the intake manifold was only there for parking (i.e., not used).
Disconnect the pipe at the front of the valve.
Start the engine.
Engine off - now the flap needs to close.
and then turn on again 2 seconds later.
See also here:
Okay, I'm ready. Please provide the German text you want me to translate into English.
Translated on 17-07-2026, 11:15.
engl
Post10-01-2012, 21:47    Subject: Throttle valve - error Quote
Well, since I didn't get a response: today I took the thing out and removed the cover.
The gears are all still in good visual condition, and the door opens and closes easily, both with and without the spring mechanism. I've flushed out some oil using a fine oil.
The fuse F8 in the engine compartment fuse box, located on the right side behind the relay when facing it, has blown. I'll replace it tomorrow and then see what happens afterward.
Otherwise, I'll just disconnect the throttle connector.
Can the speed limiter be disabled?
Translated on 17-07-2026, 11:19.
Post10-01-2012, 21:55    Subject: Throttle valve - error Quote
Kann man das Drosseldingens rausprogrammieren?
No, it's related to exhaust emissions.
You won't be able to experience the HU successfully without it icon_exclaim.gif.
Translated on 17-07-2026, 11:22.
engl
Post11-01-2012, 13:25    Subject: Throttle valve - error Quote
Fuse replaced, error cleared.
Motor 3 mal angelassen und wieder abgestellt. Error gone.
Engine revved up, error reappeared, fuse blew.
Debugging:
Replaced the 15A fuse (a tip from a friend, who has been using this for a year**). The problem disappeared.
Power output at 10 amps: 120 watts; at 15 amps: 180 watts.
Which consumer requires up to 180 watts instead of a maximum of 120 watts due to some kind of wear and tear?
I myself probably wouldn't have come up with the idea of simply installing a larger fuse, because the fuse sizing from the manufacturer already has its purpose. I only did it because another Touran has been running like this for quite some time without problems. Otherwise, I certainly don't think that this type of solution is professional! icon_wink.gif
Translated on 17-07-2026, 11:25.
Post11-01-2012, 13:33    Subject: Throttle valve - error Quote
Welcher der Verbraucher braucht nun aufgrund irgendeines Verschleißes statt maximal 120 Watt bis zu 180 Watt??
A dying throttle valve icon_idea.gif.
Translated on 17-07-2026, 11:28.
Post11-01-2012, 16:18    Subject: Throttle valve - error Quote
engl wrote:
Backup restored, error cleared.
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
Which of the consumers now needs up to 180 watts instead of a maximum of 120 watts due to some wear and tear?
Do you know which ones are actually connected behind the fuse in question?
Besides a regular consumer, it could also potentially be a short circuit fault: either something is sparking somewhere in the wiring harness, and/or another consumer is drawing (additional) power through the aforementioned fuse icon_confused.gif.
Translated on 17-07-2026, 11:29.
Post11-01-2012, 18:58    Subject: Throttle valve - error Quote
So, are you serious about the fuse replacement thing? If you replace it with a weaker one, it will just blow again. You'll need to put in a stronger one instead.
Repairing essentially means finding the root cause, not just addressing the symptoms.
Translated on 17-07-2026, 11:32.
Post11-01-2012, 21:01    Subject: Throttle valve - error Quote
If it were my car, I would already go buy a new throttle body module... icon_wink.gif
Translated on 17-07-2026, 11:33.
engl
Post11-01-2012, 21:23    Subject: Throttle valve - error Quote
In light of my efforts:
Nachdem sich das Auto in letzter Zeit zum Groschengrab entwickelt, ist es mir eigentlich auch recht, wenn ich die Symptome erfolgreich bekämpfen kann. Dieses Auto ist nicht mein Liebling, sondern mein Arbeitsgaul! Und ich weiß, ich bin knickrig; eigentlich sollte ich einfach die Kohle hinlegen und das Teil neu machen lassen. Aber dann würde ich nicht hier im Forum drüber schreiben, oder? AuBesides, I now have some time for such trivial matters; in the summer, I probably would have already had that part replaced.
Subject:
Since the fuse doesn't blow when the throttle valve is disconnected, I think the DC motor is likely the main culprit. The radiator fans are also connected to that same fuse.
The 15A fuse did not solve the problem.
Today, I received a throttle valve where some teeth are missing at the beginning of the ten-segment section. I installed a different stop so that the area with the broken teeth is no longer engaged.
I intend to try fitting this DKM part into my car tomorrow and see if it works.
Does the throttle body module need to be programmed/calibrated?
'Thank you!'
Wenns mein Auto wäre würde ich schonmal ein neues Drosselklappenmodul kaufen gehen... {icon_wink.gif}
Translated on 17-07-2026, 11:36.
Post11-01-2012, 23:51    Subject: Throttle valve - error Quote
This thing costs about the same as a full tank of gas.
Do it again and it'll be perfect!
Translated on 17-07-2026, 11:41.
engl
Post12-01-2012, 18:09    Subject: Throttle valve - error Quote
icon_cool.gif I ordered it; I should receive it tomorrow; I also ordered a mass airflow sensor at the same time, which is also brand new.
Thank you!
Translated on 17-07-2026, 11:42.
engl
Post13-01-2012, 12:30    Subject: Throttle valve - error Quote
Nevertheless, this topic doesn't leave me in peace.
Can someone tell me how to remove the throttle shaft without damaging anything?
Translated on 17-07-2026, 11:43.
No new posts Throttle Body V157 Fault, P3103 Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Caddy Bj 07 BLS AGR Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A5 throttle body Diesel Engine Technology
This topic is locked, you cannot edit or reply. Throttle Body Cleaning: T3 WBX (Solved) Gasoline Engine Technology
No new posts Polo 6N Throttle Body Initial Adjustment Gasoline Engine Technology
No new posts Adapt throttle valve Lupo 16V Gasoline Engine Technology
