Flexible pipe broken again! Should all engine mounts be replaced?
oldewurtel
Post14-02-2012, 21:00    Subject: Flexible pipe broken again! Should all engine mounts be replaced? Quote
Hello fellow enthusiasts,
After a long period of trouble-free operation and almost 20,000 km without any real issues (ball joints, water pump, and a faulty mass airflow sensor shouldn't be a major problem for a real TDI driver, right??), I've encountered a minor issue with my exhaust system.
Brief history:
8/2005: Catalytic converter rattling, monolith loose --> replaced with a new (metal) catalytic converter.
12/2008: Exhaust is very loud (flexible pipe?), and has a red emissions sticker --> PMS (Mangold/Oberland) installed.
1/2012: The exhaust is roaring again (possibly a problem with the flexible pipe)!
'In the middle of last year, I replaced the front left engine mount (due to...)' Oil leak.
Given that the average lifespan of a Flexro hose is approximately 3.2 years (or about 45,000 km), I have a question:
Should you replace all four engine mounts at the same time when replacing a damaged flex pipe?
Or are there only...? B. Are the front, hydraulic bearings more prone to failure?
I'm looking forward to your answers.
BTW: The search results yielded some entries, but nothing relevant regarding [topic]. Relationship between the lifespan of flexible pipes and motor mounts.
Best regards, K. Oldewurtel.
No new posts Rear Engine Mount for VW T6 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Interesting for all Passat owners from 1996 onwards. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Central Locking: How to Program (2002+) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Failure: Common Causes & How to Fix It Diesel Engine Technology
No new posts Defective 1Z Flex Pipe: Who is Liable? Diesel Engine Technology
No new posts Stuttering in 1Z: Troubleshooting Guide Diesel Engine Technology
No new posts Exhaust fumes again! Diesel Engine Technology
