Subaru Diagnostics: Using VCDS Hardware (Articles)
🔗 ⭐ 🖨 Dieselschrauber - Index » Troubleshooting & Guides
dieselschrauber Post24-01-2012, 9:43
FreeSSM is a diagnostic software for Subaru vehicles. It is released under the GPL (General Public License version 3.0) and runs on both Windows and Linux (utilizing the excellent Qt toolkit).
The project page for the diagnostic software is located at:
http://sourceforge.net/projects/freessm.berlios/
Our existing VCDS HEX/KEY diagnostic hardware can be used with FreeSSM.
Here's how to use our semi-professional and professional systems with a USB connection:
- Log in to the customer account and download the VCP driver (emulation of a virtual COM port).
- Follow the instructions: https://community.dieselschrauber.org/en/viewtopic.php?t=17581
- Unzip the attached file and then run the software setup for FreeSSM.
 Screenshot FreeSSM
 File size:  40 KB
 Viewed:  12077 times
FreeSSM-1.2.5-windows-qt4-installer.exe.zip
 FreeSSM-1.2.5 Windows Installer
 File name:  FreeSSM-1.2.5-windows-qt4-installer.exe.zip
 File size:  7.67 MB
 Downloaded:  1933 times
Translated on 12-08-2026, 4:36.
Ratings - Subaru Diagnostics: Using VCDS Hardware
No new posts VCDS: On-board diagnostics for VAG vehicles Troubleshooting & Guides
No new posts Zero-tolerance for deviations in the steering angle of th... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Fiat Ducato 2.8 JTD Diagnosis: Software & Hardware On-Board Diagnostics (OBD)
No new posts VCDS Hardware Update: Is it Possible? On-Board Diagnostics (OBD)
No new posts VCDS Interface Hardware: Different Versions? On-Board Diagnostics (OBD)
No new posts Update for VCDS German version 25.3.1, multi-brand diagno... On-Board Diagnostics (OBD)
